How Do You Calculate pOH and Ka for Acid Solutions?
This discussion focuses on calculating pOH and the acid dissociation constant (Ka) for monoprotic acid solutions. A strong monoprotic acid with a concentration of 2.040 x 10-1 mol/L was analyzed, yielding a pOH of 13.3 using the formula [OH-] = Kw/[H3O+]. Additionally, for a 0.2700 molar solution of an unknown monoprotic acid with a pH of 5.75, the calculated Ka was determined to be 1.17 x 10-11 using the formula KA = [H3O+][A-]/[HA].
  • Understanding of pH and pOH calculations
  • Knowledge of acid dissociation constants (Ka)
  • Familiarity with the concept of monoprotic acids
  • Basic algebra for manipulating equations
  • Study the relationship between pH, pOH, and Kw
  • Learn how to calculate Ka for polyprotic acids
  • Explore the impact of concentration on pH and pOH
  • Investigate the use of titration curves in determining Ka
Chemistry students, laboratory technicians, and professionals involved in acid-base chemistry who need to calculate pOH and Ka for various acid solutions.
Soaring Crane
1. A bottle of strong monoprotic acid was labelled as having a concentration of 2.040 x 10-1 mol/L. Given that KW = 1.00 x 10-14, determine the p0H of the acid solution.
[H3O+][OH-]= K_w
[OH-] = k_W/[H3O+] = (1.00*10^-14)/(2.040*10^-1 M) = 4.90196078E-14
-log[OH-] = pOH
-log[4.90196E-14] = pOH = 13.3096 = 13.3
2. The pH of a 0.2700 molar solution of unknown monoprotic acid was measured and found to be 5.75. Calculate the Ka of this acid.
pH = -log[H3O+]
5.75 = -log[H3O+]
antilog[-5.75] = [H3O+] = 0.000001778 = X
K_A = [H3O+][A-]/[HA] = X^2/[0.2700 - X] = (0.000001778)/(0.2700 - 0.000001778) = 1.17122166E-11 = 1.17E-11
Thanks.
For the first one you could have just found the pH and added that number from 14 to get pOH. But anyway, stick to your way since you probably memorized it already.
K_A = [H3O+][A-]/[HA] = X^2/[0.2700 - X] = (0.000001778)^2[/color]/(0.2700 - 0.000001778) = 1.17122166E-11 = 1.17E-11
Though your answer is right (you just posted what you did after finding right solution, right?), you forgot to put square 1.778E-6 in the message.
  • · Replies 22 ·
