Calculating Initial Velocity with Spring Constant and Mass: Homework Problems
The discussion focuses on calculating initial velocities using spring constants and mass in two scenarios: a cannon and a bungee jump. The spring constant for the cannon is 1800 N/m, with a compression of 0.55 m, and a 7.0 kg cannonball is released. The second scenario involves a bungee jumper with a mass of 68.0 kg and a bungee cord spring constant of 66.0 N/m, falling from a height of 46.0 m. The Work-Energy Theorem is applied to determine the initial kinetic energy from the potential energy stored in the spring and gravitational potential energy.
  • Understanding of the Work-Energy Theorem
  • Knowledge of potential energy (PE) and kinetic energy (KE) calculations
  • Familiarity with spring constants and Hooke's Law
  • Basic physics concepts related to mass and gravity
  • Study the Work-Energy Theorem in detail
  • Learn about Hooke's Law and its applications in real-world scenarios
  • Explore potential and kinetic energy calculations in physics problems
  • Investigate the dynamics of bungee jumping and energy transformations
Students studying physics, educators teaching mechanics, and anyone interested in understanding energy transformations in spring systems and gravitational contexts.
kbean5588
These questions on my homework are so hard. anyone get them?
"The Spring constant for the spring in a special cannon is 1800N/m. In cocking the cannon, the spring is compressed .55m. What is the initial speed of a 7.0 kg cannonball at rest on the free end of the spring when it is released?"
"I went bugee jumping and I was standing on a platform that is 46.0m high. My mass is 68.0kg and my bungee cord is 9.00 m long (unstretched). The cord behaves like an ideal spring and has a constant of k=66.0N/m. I fall off the platform from rest and I want you to tell me my velocity when I am (a) 37 m off the ground and (b) 15 m off the ground."
I am assuming your cannon is horizontal rather than pointing up. Use the Work-Energy Theorem. You can find the initial spring PE. You can use that to predict the final KE.
-Dan
You can find how fast the jumper is moving when the bungee cord is extended, but not stretched. (That's the 37 m reading). For the 15 m reading, you know how far the bungee cord is stretched, so you can find the PE due to that. You also know the gravitational PE. From these you can find the KE.
-Dan
