N=a^2+b^2+c^2, a.b.c.N are all integers(>0)
  • Context: Graduate
  • Thread starter Thread starter neptunecs
The discussion revolves around the representation of integers as sums of squares, specifically the equation N=a^2+b^2+c^2, where a, b, c, and N are positive integers. Participants explore the number of solutions for each N and its implications in number theory, with connections to quantum mechanics.
  • Some participants note that most integers can be expressed as the sum of three squares, but numbers of the form 8k+7 and 4^m(8k+7) cannot be represented this way.
  • Others mention that while the number of ways to represent an integer N as a sum of three squares has been solved, the solution is complex and involves slowly converging series.
  • A participant references a paper that discusses the asymptotic behavior of the summatory function related to the number of representations as sums of three squares.
  • One participant states that every positive integer can be expressed as a sum of four squares, referencing related resources.
  • Another participant provides a proof related to primes of the form 4k+1 being expressible as sums of two squares and extends this to sums of four squares.
  • A later reply points out a potential error in a previous mathematical claim regarding the representation of primes as sums of squares.
Participants generally agree on the existence of solutions for representing integers as sums of squares, but there are multiple competing views regarding the complexity of these solutions and the specific cases that cannot be represented. The discussion remains unresolved on the ease of finding a function to describe integer solutions for N=x^2+y^2+z^2.
Some limitations include the complexity of the mathematical proofs involved, the dependence on specific forms of integers, and the unresolved nature of certain mathematical steps in the discussion.
neptunecs
Hi
N=a^2+b^2+c^2,
a.b.c.N are all integers(>0),I am wondering how many solves for each N.
Have this problem been solved in Number Theory?
This problem is originate from a quantum mechanics question I met.
thanks for any advice.
neptunecs
Most numbers (integers) can be written as the sum of three squares. However numbers of the form 8k+7 and numbers of the form 4^m(8k+7), m>0, can not be so written. It is easy to show that x^2+y^2+z^2 is not congruent to 7 mod 8.
All odd squares are congruent to 1 mod 8, and even integers are congruent to 0 or 4. Thus we consider the set of residues {0,1,4}, any three of them can not total 7. http://www.artofproblemsolving.com/Forum/topic-5269.html
Thank you very much.
It's seems that this problem haven't been solved in Number Theory,it's hard to find a function s(N) to discript the int solutions of N=x^2+y^2+z^2, right?
Thanks for your opinion and information.
The number of ways to represent an integer N as a sum of three squares has been solved, but it's not simple and involves a series that converges very slowly. It's given in http://www.ma.utexas.edu/~kumchev/P4.pdf for example, and you can find other sources, just look for "sum of three squares". Much nicer asymptotics exist for the summatory function, that is if r(n)=#of ways to express n as a sum of three squares then [itex]\sum_{n\leq x}r(n)\sim 4/3\pi x^{3/2}[/itex].
Thank you very much!
I will read that paper soon,but I think it's difficult for me,because I know only a little about Number Theory ,I major in theoretical physics...
But thanks for your answer which make me know that this problem has been solved.
Neptunecs.
this is not super hard to prove. it is modeled on gauss(?) proof of fermats thm that primes of form 4k+1 are sums of two squares.
i.e. if p = 4k+1, then X^2+1 = 0 has a solution mod p. [e.g. mod 5, the solution is 1(2), and mod 13 the solution is 1(2)(3)(4)(5)(6) = 5, mod 13.]
this means that in (Z/p)[X], the polynomial X^2+1 is reducible, so that the ring (Z/p) is not a domain. but then in Z, the element p must be reducible, so p = (a+bi)(c+di), and taking absolute values of both sides, and squaring, we get p = a^2 + b^2.
Now Hurwitz defined the integral quaternions in a similar way, Z[i,j,k], (with a judicious denominator of 2), and it follows, similarly that no prime integer p is irreducible in there.
hence p = (a+bi+cj+dk)(e+fi+gj+hk), and again taking norms of both sides shows, with a little computation, that at least 4p is a sum of 4 squares.
but euler showed that if n is a sum mof 4 squares so is n/2, and applying this twice, p is a sum of 4 squares.
in both cases, the product of integers which are sums of 2 or 4 squares, is also. [this is because norms are multiplicative.] so the prime case does it all.
these proofs rely on the existence of a division algortihm in these two rings, even though the second one is non commutative.
mathwonk: so p = (a+bi)(c+di), and taking absolute values of both sides, and squaring, we get p = a^2 + b^2.
There is a small error here which I point only because it might confuse the beginning student, you mean p = (a+bi)(a-bi)=a^2+b^2.
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 17 ·
