Conservation of energy and conservation of momentum
The discussion revolves around deriving the spring constant \( k \) using the principles of conservation of energy and conservation of momentum within the context of a mass-spring system. Participants are exploring the relationships between kinetic energy, momentum, and the spring constant in a potentially relativistic scenario.
  • Mixed
  • The original poster attempts to relate kinetic energy to momentum but struggles with the change in momentum. There are questions about the definitions of symbols used in the problem, particularly regarding mass and velocity.
Participants are actively questioning the definitions of terms and the setup of the problem. Some express curiosity about the implications of relativistic effects on simple harmonic motion, while others indicate a shift in approach is necessary. There is no explicit consensus on the method to derive the spring constant.
There are indications that the problem may involve relativistic considerations, which adds complexity to the discussion. Some participants express frustration over the lack of clarity in the definitions provided in the question.
sauri
Using both cinservation of energy and conservation of momentum, show that the spring constant k is given by k=2mg/H[1+mg/(m+M)H]
I thought that this would go easier if I rewrote the expression for kinetic energy in terms of momentum, but I can't exactly get around figuring the change in momentum to build an equation. would (m1v1/2) be correct?
Do you have defintions for your symbols?
as in initial mass and initial velocity?
"Initial mass?" : Perhaps you'd better tell us what the question is.
-Dan
-Dan
Hmm, a mass spring system oscillating at close to the speed of light. I've never done relativistic effects with SHM before...could be interesting...
It seems I have taken a wrong approach. I need to show that the spring constant k can be given by 2mg/H[1+mg/(m+M)H] using thr conservation of energy and momentum.
Does the question not give you any definitions for the symbols used?
I worked it out. No matter
:mad: Then at least have the decency to tell us! You've got ME curious, anyway.
-Dan
  • · Replies 18 ·
  • · Replies 20 ·
