Angular speed of student on merry-go-round
The discussion centers on calculating the angular speed of a student on a merry-go-round as they move from the rim towards the center. The initial angular speed is given as 1.5 rad/s, with the platform's mass at 150 kg, radius at 2.0 m, and rotational inertia at 300 kg·m². Participants emphasize using the conservation of angular momentum to determine the new angular speed when the student is 0.5 m from the center, noting that the student's mass affects the moment of inertia. The relationship between torque, moment of inertia, and angular acceleration is also highlighted as a method for solving the problem.
  • Understanding of angular momentum conservation principles
  • Familiarity with rotational inertia and its calculation
  • Knowledge of torque and its relationship to force and radius
  • Basic concepts of angular speed and its calculation
  • Study the principles of conservation of angular momentum in closed systems
  • Learn how to calculate moment of inertia for various shapes
  • Explore the relationship between torque, angular acceleration, and moment of inertia
  • Practice problems involving angular speed changes in rotating systems
Physics students, educators, and anyone interested in understanding rotational dynamics and angular momentum in mechanical systems.
sauri
A merry go round can be described as a horizontal platform in the shape of a disc which rotates on a frictionless bearing about a vertical axis through its centre. The platform has a mass of 150 kg, a radius of 2.0 m and a rotational inertia of 300 kg.m2.A 60 kg student walks slowly from the rim of the platform toward the centre. If the angular speed of the system is 1.5 rad.s-1 when the student starts at the rim, what is the angular speed when he is 0.5 m from the centre?
I know that w=2(pi)/T=2(pi)r and the kinetic energy= (mr^2w^2)/2, but I am not sure how these two are to be related, if these are the correct equation to begin with.
There are no external torques on the system. Try conservation of angular momentum.
-Dan
Use conservation of momentum and remember that the student's mass adds mass to the moment of inertia.
If you want to do it the long way:
The student's weight exerts greater torque on the merry go round as it approaches the center. The torque=force*radius. The torque also equals the moment of inertia * acceleration. Solve for acceleration. Convert angular to linear because you do not know delta theta. Then use the kinematic equation to solve for your linear speed. Then divide by your new radius.
I think that is how I would do it if you do not want to use conservation of momentum.
