Direction of static friction while rolling
The discussion revolves around the direction of static friction in the context of rolling objects, specifically comparing a wheel undergoing pure rolling and a ball sliding down a ramp. Participants explore the differing roles of friction in these scenarios and question the underlying principles governing these behaviors.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants examine the assertion that static friction acts in the direction of the center of mass acceleration for rolling wheels, while it opposes acceleration for sliding balls. Questions arise about the validity of these assertions and the reasoning behind the differing frictional directions.
Some participants have provided clarifications regarding the roles of friction in both scenarios, noting that friction prevents slipping and contributes to the motion of the wheel. Others express confusion about the implications of these roles and seek further clarification on the concepts of static versus kinetic friction in different contexts.
Participants are discussing scenarios involving rolling without slipping on inclined and horizontal planes, as well as the relationship between static and kinetic friction coefficients. There is an acknowledgment of the need for external forces to facilitate acceleration in rolling objects.
arunbg
In my physics textbook (Resnick, Halliday, Walker) , it is given that the direction of force of static friction acting on a wheel undergoing pure rolling without sliding on the ground and whose centre of mass is accelerating uniformly, is the same as the direction of acceleration of COM.
However when a ball sliding down a ramp is considered, the direction is given opposite to the acceleration( up the ramp) , the reason given that the wheel has a tendency to slide down the ramp and friction must oppose this tendency.
I find that the first scenario is only a generalisation of the second with a=g . But then why is the direction of friction different?
Or is one of these assertions wrong ?
Both assertions are correct. In the first case, the friction is the cause of the (translational) acceleration. In the second case, gravity provides the accelerating force while the friction reduces the net force (as it also provides a torque to keep the ball rolling).
Note that in both cases the friction opposes slipping between the surfaces. In the first case, the wheel surface would slip towards the rear without sufficient friction towards the front opposing it. In the second case, the ball surface would slip forwards if it didn't rotate, thus the friction must act towards the rear to oppose it.
Hmm, So Doc you mean that in the first case friction is actually causing the translational motion and moves the COM and rotation of the wheel is basically due to the external force ? Could you please clarify case 1 a bit more?
THanks for the reply.
I assume that the rolling wheel is not being pulled by any other external force. In order for it to accelerate, there must be an external force acting on it; that external force is the friction of the road on the wheel.
Picture a car trying to accelerate. If there were no friction, you could press on the gas pedal all day and still not change the car's velocity. It requires an external force to accelerate.
Ok now I get it, so you mean to say that the rotation of the wheel is internal while friction translates.This wasn't given in the book clearly and so I got confused.
Thanks a lot Doc
I'm not saying that at all. Friction exerts a force on the wheel; that force also produces a torque.
Ok so friction translates forward and slows down rotation due to internal force ,right?
That sounds better.
But the main thing to take away from this discussion is that friction always acts to prevent slipping between surfaces. So if you can figure out which way the surfaces are trying to slip, you can easily determine the direction of the friction force.
thanx doc Al
doc al i still can't understand why the direction of friction on a straight road is with the direction of motion of the principle of preventing sliding on a straight road hard
State the exact situation you are trying to understand. Is there acceleration?
okay forget what i said my question is
about the rolling i need to know the difference between sliding and non sliding if an inclined plane and a horizontal plane aand how should i act at each problem?
my second question is in an inclined plane what is the relation between the coefficient of static friction and kinetic friction i heard that if the coefficient i get is less than the coefficient of the static coefficient given it is called kinetic how is that
Assuming something--a cylinder say--is rolling without slipping, then the only friction involved will be static friction.
If the cylinder is just rolling down a hill (nothing pulling it but gravity), then the friction acts in the opposite direction of the motion. If it's rolling along a horizontal surface, then the speed is constant and there's no friction required. (At least in the ideal case.)
To figure out the amount of static friction in the first case, you'd need to apply Newton's laws.
When sliding is involved, then you have kinetic friction. Kinetic friction can be calculated using μN.
  • · Replies 30 ·
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 32 ·
