Are there specific conditions for functions in a non-documented metric?
  • Context: Graduate
  • Thread starter Thread starter leon1127
    Analysis
The discussion revolves around the properties of compactness in sets, particularly in relation to finite and infinite sets, as well as the conditions for defining a metric that is not documented in standard texts. Participants explore various statements about compactness, open sets, and the implications of having maximum and minimum elements in a set.
  • Some participants argue that every nonempty finite set is compact, citing that finite sets must be bounded, but question whether they are closed.
  • Others challenge the claim that no infinite set is compact, providing counterexamples such as [0, ∞) and [0, 5].
  • There is a discussion about the union of open sets being open, with some participants questioning the relevance of boundary points in this context.
  • Some participants assert that having a maximum and minimum implies a set is compact, while others argue that this does not necessarily mean the set is closed.
  • Participants discuss the definition of open sets and the conditions under which a set can have a maximum and minimum while not being closed.
  • One participant mentions the need for conditions on functions when defining a metric using the Riemann integral, questioning if continuity or monotonicity is required.
Participants express differing views on the properties of compactness, particularly regarding finite and infinite sets, and the definitions of open and closed sets. The discussion remains unresolved with multiple competing perspectives.
Some arguments rely on specific definitions of compactness and open sets, which may vary. There are unresolved questions about the implications of maximum and minimum elements in relation to closedness and openness of sets.
leon1127
i need to mark statements below true or false and justify.
a) every nonempty finite set is compact.
since a finite set must have upper and lower bounds, thus it must be bounded. thus my question becomes that if a finite set is closed. i am considering a closed set [0,5] subset of R finite or not. it seems like it is not infinite set thus it is not compact. but i don't know if my argument is valid or not.
b) no infinite set is compact.
false, counterexample is [0,inf) subset of R
c)the union of any collection of open sets is an open set.
true because it is the size of such set shall only increase and the boundary point of the union set never conatined in the set.
d)if a set has a max and a min, then it is compact.
max and min imply it is bounded and closed, thus it is a compact set.
e) if a nonempty set is compact, then it has a max and min.
similar argument as d since the inverse is true.
and the last question was that find an example of a metric that is not shown in the book.
i use riemann integral[ |f-g|] and shown 4 properties of metric. what conditions do i need to put on functions f and g?
i said they are from R^n to R and continous. Do i need to state that they are increasing/decreasing monotonically too?
thx for any advice
What IS your argument? To show that a finite set is closed, simply look at the definition. How is [0, 5] not infinite? But then again, I fail to see the relevance of [0, 5] at all for this question.
[0, inf) is not compact.
I can't make sense of this at all. How are boundary points related to this question? I encourage you to simply look at the definitions.
Having a maximum/minimum most certainly does NOT imply that a set is closed.
It's indeed true.
i mean i think [0,5] is not finite since it is uncountable.
counterexample for statement 2 is also [0,5].
because if the all boundary points isn't contained in such set, the set is said to be open.
Max and min exist imply that the lower and upper bounds exist and they are elements of that set. I can't think of any set that is open but contain max and min.
I don't think this definition (characterization) of open sets is the easiest one to work with in this case. What about "a set M is open iff there exists a neighbourhood X around each point x in the set such that X is contained in M"?
You don't need to find an open set which has a max and min, you need to find a set which is not closed and has a max and min. Note that "not closed" is not the same as "open".
Think about unions of intervals...
It is true that a closed and bounded set in Rn is compact.
However, it true that a finite set in any topology is compact- that follows immediately from the definition of compact as "every open cover contains a finite subcoverf". What definition of compact are you using?
i figured it out. thanks a lot!
11K
