Thread Closed
Radiation Reaction Force (or Self Force of charge particle)
Share Thread Thread Tools
Mar20-06, 01:09 PM   #1
Unhappy
Is it true that there are cases in which the radiation reaction force on an electron is nonzero even if its acceleration is constant? I am confused because the radiation reaction force is proportional to the time derivative of the acceleration.
Also when considering the radiation reaction force (or self-force) as a series, the first term, proportional to the acceleration goes to infinity for a point charge. In this case how would you treat a charged particle in free fall, i.e. what would be its equation of motion? And I am assuming that this particle should radiate as it is in free fall, since radiation is proportional to the square of the acceleration.
Please HELP! :)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar20-06, 02:17 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by martinan
Please HELP! :)
Welcome to PF.
This is a difficult but very interesting issue. There seems to be a disagreement whether acceleration causes a charged particle to radiate.
See for example the discussion here:
Gravitational acceleration will not cause a charge to radiate. It seems that charges radiate only when interacting with other electric fields. A charge will, of course, accelerate in such a situation. But can we say that it is the acceleration rather than the interaction with the other field that causes the radiation?
In my view, all we can say is that radiation is observed when a charge experiences a time dependent interaction with another electric field. There is no need to invent the radiation reaction force or the concept of self-interaction. The laws of physics seem to be the same without it.
AM
Mar20-06, 04:18 PM   #3
What about the Larmor formula (or for v~c Lienard's generalization of the Larmor formula) which gives the total power radiated by an accelerating charge? It is proportional to a^2. This was derived using only the electric and magnetic field of the moving charge and did not consider the interaction with other fields.
As for the radiation reaction force, isn't it true that this 'self force' increases the the inertia of the charged particle and therefore a charged particle will experience less acceleration than a particle of the same mass subject to the same force?
Mar20-06, 06:46 PM   #4
Recognitions:
Quote by martinan
There is a relationship between acceleration and force, of course. The force is supplied, in the case of a charge, by the charge's interaction with another electrical field. So, although expressed in terms of acceleration, it can be just as easily expressed in terms of force.
My point is that you cannot just look at acceleration. Acceleration cannot occur without an external field interacting with the charge. The math may be equivalent, but the underlying physical explanation is not. It makes it difficult to explain, for example, why acceleration caused by gravity does not cause a charge to radiate.
AM
Mar20-06, 08:59 PM   #5
Mentor
Quote by Andrew Mason
AM
But the acceleration of any freely falling object, including an electric charge, is zero, i.e.,
[tex]\mathbf{a} = \nabla_{\mathbf{u}} \mathbf{u} = 0.[/tex]
Regards,
George
Mar20-06, 09:39 PM   #6
But the covariant acceleration is not equivalent to the regular classical time rate of change of the velolcity, which is the acceleration that the Larmor formula refers to. Isn't there a classical explanation?
Mar21-06, 07:50 AM   #7
Mentor
Quote by martinan
According to Jackson, the special relativistic generalization of the Larmor formula gives that the power radiated is proportional to the "length" of the charge's 4-acceleration, where "length" means with respect to the Minkowski space "inner product". So, no 4-acceleration, no radiation. I would think that this still holds true in general relativity, which means that freely falling electrons don't radiate.
If gravity isn't a force, then, as Andrew Mason says, only an electromagnetic field can accelerate an electron.
Regards,
George
Mar21-06, 08:39 AM   #8
Recognitions:
Quote by martinan
Please HELP! :)
The textbooks that say that uncritically follow Lorentz of over one hundred years ago. He derived it for an oscillating charge and they apply it to a charge that is not oscillating. The formulas in Jackson and elsewhere are wrong as the obvious catastrophes that follow (in Jackson) demonstrate.
Thread Closed
Thread Tools
Similar Threads for: Radiation Reaction Force (or Self Force of charge particle)
Thread Forum Replies
Given magnetic field, particle charge, and force (vector)... Calculate velocity? Advanced Physics Homework 7
Does a UNIFORMLY accelerating charge radiate? What about radiation reaction force? General Physics 1
Coulomb Force Between A Charge Rod & A Particle General Physics 1
Radiation reaction for a uniformly accelerated charge General Physics 2
Radiation Reaction Force Classical Physics 0
