How Can We Obtain Frame-Free Vector Derivative?
  • Context: Graduate
  • Thread starter Thread starter kryptyk
    Derivative Vector
The discussion focuses on obtaining a frame-free vector derivative using the \nabla operator in vector analysis. Hestenes and Sobczyk provide a frame-free definition of \nabla by defining the directional derivative and the differential of a function, leading to the expression for the derivative of F with respect to the vector \mathbf{x}. The conversation highlights the challenge of achieving a completely frame-free evaluation, with participants noting that while the notation is frame-free, practical calculations often necessitate the use of a frame. The example of the function F(\mathbf{x})=|\mathbf{x}|^r illustrates the transition from frame-dependent to frame-free expressions.
  • Understanding of vector calculus and the \nabla operator
  • Familiarity with directional derivatives and differentials
  • Knowledge of frame and reciprocal frame concepts in vector analysis
  • Basic proficiency in mathematical notation and functions
  • Study Hestenes and Sobczyk's work on geometric algebra and frame-free calculus
  • Explore advanced topics in vector analysis, focusing on frame-independent functions
  • Learn about the chain rule in the context of vector derivatives
  • Investigate applications of frame-free derivatives in physics and engineering
Mathematicians, physicists, and engineers interested in advanced vector calculus, particularly those exploring frame-free methods in analysis and applications in theoretical physics.
kryptyk
In vector analysis, it is possible to express the [tex]\nabla[/tex] operator in terms of a frame[tex]\{\mathbf{e}_1, \mathbf{e}_2, ..., \mathbf{e}_n\}[/tex] and its reciprocal frame [tex]\{\mathbf{e}^1, \mathbf{e}^2, ..., \mathbf{e}^n\}[/tex] by:
[tex]\nabla = \sum_{k=1}^n \mathbf{e}^k \frac{\partial}{\partial x^k}[/tex]
where [tex]x^k[/tex] are the vector coordinates for frame [tex]\{\mathbf{e}_k\}[/tex]:
[tex]\mathbf{x} = \sum_{k=1}^n x^k \mathbf{e}_k[/tex]
Hestenes and Sobczyk[84] instead present a frame-free definition of [tex]\nabla[/tex] by first defining the directional derivative of some function of a vector via:
[tex](\mathbf{a}\cdot\nabla_{\mathbf{x}})F(\mathbf{x}) = \lim_{\tau\rightarrow 0}\frac{F(\mathbf{x} + \tau \mathbf{a})-F(\mathbf{x})}{\tau}[/tex]
They then define the differential of [tex]F[/tex] by:
[tex]\underline{F}(\mathbf{x}, \mathbf{a}) = (\mathbf{a}\cdot\nabla_{\mathbf{x}})F(\mathbf{x})[/tex]
from which they then claim we can obtain the derivative of [tex]F[/tex] with respect to the vector [tex]\mathbf{x}[/tex] by:
[tex]\nabla_{\mathbf{x}} F(\mathbf{x}) = \nabla_{\mathbf{a}}(\mathbf{a}\cdot\nabla_{\mathbf{x}})F(\mathbf{x}) = \nabla_{\mathbf{a}} \underline{F}(\mathbf{x}, \mathbf{a})[/tex]
I just don't understand how this last equation allows us to obtain the derivative in a frame-free manner. I still find it necessary to introduce a frame and use partial derivatives. Once the derivative has been evaluated, the frame-dependence can be removed. For example, let
[tex]F(\mathbf{x})=|\mathbf{x}|^r[/tex],
then
[tex]\nabla F = \sum_{k=1}^n \mathbf{e}^k \frac{\partial}{\partial x^k}F(x^1, x^2, ..., x^n)[/tex]
For orthonormal frame [tex]\{\mathbf{e}_k\}[/tex] we can write:
[tex]F(\mathbf{x}) = |\mathbf{x}|^r = |(x^1)^2 + (x^2)^2 + ... + (x^n)^2|^{\frac{r}{2}}[/tex]
where [tex](x^k)^2[/tex] means the square of the kth component and the [tex]k[/tex] is not to be interpreted as an exponent. (Yes, this notation is a bit ugly but it seems to be quite engrained in the literature.)
Since [tex]\{\mathbf{e}_k\}[/tex] is an orthonormal frame, for Euclidean spaces we have [tex]\mathbf{e}^k = \mathbf{e}_k[/tex] and so
[tex]\mathbf{e}^k \frac{\partial}{\partial x^k}|(x^1)^2 + (x^2)^2 + ... + (x^n)^2|^{\frac{r}{2}} = r |\mathbf{x}|^{r-2} x^k \mathbf{e}^k = r |\mathbf{x}|^{r-2} x^k \mathbf{e}_k[/tex]
thus,
[tex]\nabla_{\mathbf{x}} |\mathbf{x}|^r = \sum_{k=1}^n r |\mathbf{x}|^{r-2} x^k \mathbf{e}_k = r |\mathbf{x}|^{r-2} \mathbf{x}[/tex]
and so we finally arrive at a frame-free expression for the derivative.
Can this evaluation be carried out in a completely frame-free manner? Would such an approach easily generalize to any frame-independent function of [tex]\mathbf{x}[/tex]? I'm finding it easier to just evaluate them like I did here - but it seems perhaps by means of the chain rule it can be done more elegantly without mention of frames at all.
It always depends on what you want to use it for. Of course you need coordinates (a frame) whenever you actually calculate something. The notation with the nabla operator is per se frame-free - and sufficient if we are interested in the transformation it expresses rather than the numbers it spits out at a certain point for a certain function.
