Can Poles of Integer Order be Eliminated in the Redefinition of Integrals?
  • Context: Graduate
  • Thread starter Thread starter eljose
    Integral
The discussion revolves around the possibility of redefining integrals that diverge due to the presence of poles of integer order in the integrand. Participants explore methods to assign finite values to such integrals, considering the treatment of poles and the use of residues.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests redefining the integral by considering the residues of the poles, proposing an expression that includes the integral plus the sum of residues.
  • Another participant agrees that if there are a finite number of poles, one can integrate around the poles and conclude that the integral over the original area equals the sum of the residues.
  • A different viewpoint highlights that divergence can also arise from the behavior of the function at infinity, not solely from the poles, and questions the applicability of residues to functions that are not complex analytic.
  • One participant inquires about methods to avoid singularities in the integrand altogether.
Participants express differing views on the conditions under which residues can be applied and the reasons for divergence, indicating that multiple competing perspectives remain unresolved.
There are limitations regarding the assumptions made about the nature of the function F(x), particularly concerning its behavior at infinity and the types of singularities present.
eljose
Let,s suppose we have the integral:
[tex]\int_{-\infty}^{\infty}dxF(x)[/tex]
but unfortunately we have a problem..the function F(x) has several poles of integer order r (r=1,2,3,4...) so it diverges :rolleyes: :rolleyes: :rolleyes: then my question is if there is a form to redefine our integral so it can be assigned a finite value by "eliminating" somehow its poles considering them as residues so finally we have an integral:
[tex]\int_{-\infty}^{\infty}dxF(x)+ Res(F)[/tex] where the integral is
finite and Res(F) would be the sum of the residues of F(x) at its poles...or something similar..pehaps with the "Cauchy principal value integral"?...
Of course you can (assuming a finite number of poles): place small circles around the poles and integrate over the remaining area. Of course, if your function has only poles as singularities, then its integral on this new domain is 0 so the integral on the original area is just the sum of the residues. But we knew that already, didn't we?
That's not the only reason a function may diverge. F(x) also fails to converge to zero as x goes to infinity. And even if it did go to zero, it might not do it fast enough.
Speaking about residues, AFAIK, only make sense if you're talking about complex analytic functions.
But..is there a way to "avoid" the singularities of the integrand?..
  • · Replies 16 ·
