Pdf of the sum of two distributions
The discussion centers on the probability density function (pdf) and distribution function of the sum of two independent and identically distributed (iid) uniform random variables, X and Y, both following U(0,1). The convolution of their densities leads to specific integral bounds for calculating the pdf: for 0 < z < 1, the pdf is f_X+Y(z) = z, and for 1 < z < 2, it is f_X+Y(z) = 2 - z. The distribution function F_X+Y(z) is derived similarly, with distinct integral limits based on the value of z, reflecting the constraints of the uniform distribution.
  • Understanding of probability density functions (pdf)
  • Knowledge of convolution of probability distributions
  • Familiarity with integration techniques
  • Concept of independent and identically distributed (iid) random variables
  • Study the properties of convolution in probability theory
  • Learn about the Central Limit Theorem and its implications for sums of random variables
  • Explore the derivation of distribution functions from pdfs
  • Investigate other distributions, such as the Normal distribution, and their convolution properties
Students and professionals in statistics, data science, and quantitative fields who are working with probability distributions, particularly those interested in understanding the behavior of sums of random variables.
shan
I'm not too sure where to post this so feel free to move it :)
Anyway I'm hoping someone could explain the answer of this problem to me (I would ask my lecturer but he's conveniently away for the week for a meeting).
Suppose X and Y are iid continuous random variables with density f. Then X+Y has density:
f_X+Y(z) = integral from infinity to neg infinity of f(x)f(z-x)dx
which is the convolution of the densities of X and Y.
Use this to determine the pdf (probability density function) and distribution function of X+Y when X and Y are iid U(0,1). (independently and identically distributed, Uniform(0,1)).
The answer starts by showing the region where f(x)f(z-x) is non-zero ie the area between z-x=0 and z-x=1 (and I understand this part, if X and Y are uniform, the sum will be 0 outside (0,2)). It then says that the density function is:
For 0<z<1
f_X+Y(z) = (integral from z to 0 of 1dx) = (x evaluated at z and 0) = z.
For 1<z<2
f_X+Y(z) = (integral from 1 to z-1 of 1dx) = (x evaluated at 1 and z-1) = 2-z.
I don't understand why for 1<z<2, the integral is from 1 to z-1? Where did these boundaries come from?
The other part is the distribution function which is supposedly:
For 0<z<1
F_X+Y(z) = (integral from z to 0 of wdw) = (w^2/2 evaluated at z and 0) = z^2/2
For 1<z<2
F_X+Y(z) = (integral from z to 0 of f_X+Y(w)dw) = (integral from 1 to 0 of f_X+Y(w)dw + integral from z to 0 of f_X+Y(w)dw)
= (integral from 1 to 0 of wdw + integral from z to 1 of (2-w)dw) = 1^2/2 + (2w-w^2/2) evaluated at z and 1)
= 1/2 + (2z-z^2/2)-(2-1/2) = 2z-z^2/2-1
Again, I'm having problems with where the numbers in the integral came from when 1<z<2.
Sorry for the hard read >_< I can't seem to preview the latex images and since I don't know how to use them very well I thought I could do without...
Hi there!
It looks like you are having some confusion with the integration limits of your problem. The bounds of the integral will depend on the value of z. When 0 < z < 1, the integrand is non-zero between 0 and z, so the integral should be taken from 0 to z. When 1 < z < 2, the integrand is non-zero between 1 and z-1, so the integral should be taken from 1 to z-1.
The reason for this is that X and Y are uniform on (0,1). This means that the sum X+Y can not be greater than 2, since if both X and Y = 1 then X+Y = 2. Therefore, when z > 1, the integrand f(x)f(z-x) must be equal to 0 for x > 1, since otherwise the sum would exceed 2. This is why the upper bound of the integral when 1 < z < 2 must be z-1 instead of z.
I hope this explanation was helpful in understanding your question!
