Can a Tachometer Measure the Torque of a Rotating Disc?
The discussion centers on using a tachometer to measure the rotational speed of a disc connected to a gearbox and AC motor in order to calculate torque. The user intends to apply the formula T = I x α, where T is torque, I is moment of inertia, and α is angular acceleration. Recommendations include reducing the sampling interval from 10 seconds to 1 second or faster, ideally at 10 Hz or higher, to improve the accuracy of torque calculations. The consensus emphasizes that without proper instrumentation, achieving reliable torque measurements will be challenging.
  • Understanding of angular acceleration and moment of inertia
  • Familiarity with tachometers and their operation
  • Basic knowledge of torque calculations
  • Experience with sampling rates and data acquisition
  • Research how to calculate angular acceleration using tachometer data
  • Explore methods for improving data sampling rates in mechanical systems
  • Learn about torque measurement techniques and instrumentation
  • Investigate alternatives to tachometers for measuring rotational speed
Mechanical engineers, hobbyists working on rotating machinery, and anyone interested in torque measurement and rotational dynamics.
nicole2000
Hello All!
I have one machine. The disc (Horizontal place) is rotating and connecting to the shaft which is connecting to gear box and ac motor.
I would like to k now the torque of rotating disc for some interval such as 10s, 20s, 30s, to take reading , but I do not have money to buy torque meter.
I would like to know can I use tachometer to take the rotation speed of rotating disc within interval, 10s per taking.
And then I can use T= I x aplha to find the different time's torque reading
Please advise me.
Or could you please give me another ideas or suggestions?
Thanks a lot.
That's an extremely rough way to do it. If you were to go that route, I would recommend that you reduce that 10 sec interval to less than a second. If you can sample the speed quicker, say 10 Hz or better, you will have a better resultant calculation of the torque, especially if you are trying to see the result of an applied load.
Without proper instrumentation, I don't see how you're going to get any better results that easily.
  • · Replies 25 ·
  • · Replies 46 ·
