source free RL circuit confusion! When this switch closes, does the current end?
by mr_coffee
Tags: circuit, closes, confusion, current, free, source, switch
mr_coffee
mr_coffee is offline
#1
Mar26-06, 10:35 AM
P: 1,629
Hello everyone. I'm getting confused on what my professor did. Everything else makes sense to me but this one part. THe directions say:
Aftering having been closed for a long time, the switch in the circuit is opened at t= 0. (a) find IL(t) for t>0, (b) Evaluate IL(10ms).
I got both parts right. Here is my work and the circuit:
Okay if you look at t<0, you assume the inductor is short circuit, thats what those 2 little dots mean instead of the curly inductor symbol. THe current Io = IL. So when the switch is closed, if you notice the circuit is redrawn, with the 20 and 10 resistors in series not even in the circuit. When that switch is closed for along time, its DC current. But wouldn't the current branch off into 2 parts? 1 going into the 20 + 10 resistors on the left and another current going to the right through the 50 ohm resistor and then going into where the inductor was?
What i'm confused on is why U can just say screw those other resistors, Io isn't affected by them. Any explanation? Thanks!
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
nrqed
nrqed is offline
#2
Mar26-06, 11:52 AM
Sci Advisor
HW Helper
P: 2,886
Quote Quote by mr_coffee
It`s not that the 10 and 20 ohms disappear. It is simply that the potential difference across the 50 ohms is 100 V (and the potential difference across the 10 and 20 ohms combined is also 100 volts). Do you see this? (it`s clear since the terminals of the battery are directly connected across the 50 ohms). So if you only want the current across the 50 ohms, you simply divide 100V by 50 ohms. However, at the same time, the current through the other two resistors is 100V/30 ohms = 3.33 A. But you did not need that information to proceed so there was no need to calculate it.
Hope this helps
Pat
mr_coffee
#3
Mar26-06, 12:00 PM
P: 1,629
ahhh i c now! thanks Pat, helped alot!
Register to reply
Related Discussions
General SEcond Order Circuit: 2 Res. - 2 Inductors - Current Source Introductory Physics Homework 17
circuit with capacitor, current source, voltagr source... and a switch Engineering, Comp Sci, & Technology Homework 1
CIRCUIT ANALYSIS: Use superposition - 2 Current source, 1 Voltage source, 4 resistors Advanced Physics Homework 6
EECS: Find i_0 in a circuit with 4 resistors and 1 indep. current source Engineering, Comp Sci, & Technology Homework 5
Source-free 2nd order lin. circuit Introductory Physics Homework 1
