How Does Object Shape Influence Water Flow Patterns?
This discussion centers on the influence of object shape on water flow patterns, specifically within the context of fluid dynamics. The participant conducted an experiment by pouring water on a surface and observing the flow patterns created when an object, such as a hand, was introduced. Key observations included the distinction between laminar and turbulent flow, with laminar flow exhibiting smooth, steady movement and turbulent flow displaying chaotic characteristics. The participant seeks to understand how variations in object shape and size affect these flow patterns.
  • Basic understanding of fluid dynamics principles
  • Knowledge of laminar and turbulent flow characteristics
  • Familiarity with experimental observation techniques
  • Ability to analyze visual data from experiments
  • Research the principles of fluid dynamics using resources like "Fundamentals of Fluid Mechanics" by Munson et al.
  • Learn about the Reynolds number and its role in determining flow types
  • Explore visualization techniques for fluid flow patterns, such as dye injection or particle image velocimetry
  • Investigate the effects of different object geometries on fluid flow using computational fluid dynamics (CFD) software
This discussion is beneficial for high school students studying physics, educators teaching fluid dynamics concepts, and anyone interested in experimental physics and fluid behavior around objects.
ArielGenesis
I have a physics project and i chose the topic of fluid dynamic (i don't know of it is really fluid dynamic but i think that is close enough). My level is only a high school student for information, in order to avoid any over complicating explenation.
The concept is simple:
first pour a glass of water on the florr.
Then you can see a the water spread
Wait until it stop spreading
Then the water have a certain thick ness
I some how able to have a flowing water of that thickness at a constant speed
then i put an object, like my palm for instance
the water would create a very interesting pattern.
The pattern could show a laminar flow.
I am not sure if what i thought as turbulet flow is actually a turbulent flow. coz the flow are not smooth yet stil fully transparent and no vortex has appear.
my problem is that i can't explain the pattern form in association with the shape and size of the object, if i change my palm with some thing for example.
i had taken some picture any i have trouble of posting it,
i made some attemp on analyzing the pattern, however, i can't be sure if my analysis is correct.
the pictures were at www.geocities.com/arian_m3/fluid.html
thank you. and sorry about my english
I repost this as in the last post, i posted big images which was untidy amd i had difficulty to edit them.
Fluid dynamics is the study of the motion of fluids and the forces on them. It can be used to describe the motion of water, air, and other fluids, as well as the forces acting on them. In your experiment, you are observing the effects of a flow of water around an object, such as your hand. Depending on the shape and size of the object, the water will flow around it in different ways, creating different patterns. These patterns can be used to identify different types of flows and to understand the forces that are acting on the object. For example, laminar flow is characterized by a smooth, steady flow of water, while turbulent flow is characterized by an unpredictable, chaotic flow. By changing the shape and size of the object, you can observe different patterns of flow and different forces acting on the object.
  • · Replies 29 ·
  • · Replies 21 ·
