| Thread Closed |
determine the temperature of the blood/ Heat problem |
Share Thread | Thread Tools |
| Mar29-06, 11:09 AM | #1 |
Blood can carry excess energy from the interior to the surface of the body, where the energy is dispersed in a number of ways. While a person is exercising, 0.8 kg of blood flows to the surface of the body and releases 2050 J of energy. The blood arriving at the surface has the temperature of the body interior, 37.0°C. Assuming that blood has the same specific heat capacity as water, determine the temperature of the blood that leaves the surface and returns to the interior
ok..I know that DELTA T = Q/cm Q= heat since i dont have the heat..i had to find it...so i did this Q=( CM ) ( DELTA T ) = ( 4186 ) ( .8 ) ( 37.0 °C - 15.0 °C ) = 73673.6 J now I got the heat...so i can apply this formula to find the temperature.. DELTA T = Q/cm = 73673.6 / ( 4186 ) ( .8 ) = 22 °C but still..i keep getting it wrong... ..does any one knows what im doing wrong ??..
| Mar29-06, 11:49 AM | #2 |
Mentor
Where did you get the 15.0 °C ? (The final temperature of the blood is what you are trying to find.) |
| Mar29-06, 12:20 PM | #3 |
ok.....so it should be
2050 / ( 4186 ) ( .8 ) = 0.612 BUT IT STILL WRONG..... ok..is it 37.612 ? |
| Mar29-06, 12:27 PM | #4 |
Mentor
What did you get for the temperature of the cooled blood?
| Mar29-06, 12:28 PM | #5 |
Mentor
| Mar29-06, 12:30 PM | #6 |
| Mar29-06, 12:39 PM | #7 |
thanx alot Dr Al
| Oct20-08, 09:27 AM | #8 |
I have a similar problem to this but I don't understand it. Where did you guys get the 4186?
(the problem I have is...Blood can carry excess energy from the interior to the surface of the body, where the energy is dispersed in a number of ways. While a person is exercising, 0.6 kg of blood flows to the surface of the body and releases 2000 J of energy. The blood arriving at the surface has the temperature of the body interior, 37.0°C. Assuming that blood has the same specific heat capacity as water, determine the temperature of the blood that leaves the surface and returns to the interior... so basically same thing, just different numbers) |
| Oct20-08, 09:48 AM | #9 |
Recognitions:
You have to know/look this up, it's an experimental value. |
| Oct20-08, 10:00 AM | #10 |
Thank you, mgb_phys! I get it now!
| Thread Closed |
| Thread Tools | |
Similar Threads for: determine the temperature of the blood/ Heat problem
| Temperature/Heat Help | Introductory Physics Homework | 5 | ||
| determine the time rate at which heat is supplied to the engine | Advanced Physics Homework | 5 | ||
| Blood Temperature Question | Introductory Physics Homework | 2 | ||
| determine the heat of reaction | Biology, Chemistry & Other Homework | 4 | ||
| Heat/Temperature Physics Problem | Introductory Physics Homework | 1 | ||
