What is the change in momentum?
The problem involves calculating the change in momentum of a rubber bullet that strikes a wall and rebounds. The subject area is physics, specifically focusing on momentum and its directional properties.
  • Participants discuss the calculation of momentum change, questioning the treatment of direction and magnitude. There is an exploration of vectorial considerations and the impact of sign conventions on the final result.
Some participants have provided insights into the importance of direction in momentum calculations. There is an acknowledgment of differing interpretations regarding the change in velocity and its effect on the final momentum value. The discussion is ongoing, with various perspectives being shared.
Participants note potential confusion arising from the problem's setup and the book's answer, suggesting that assumptions about directionality may need to be clarified. There is also mention of the problem being presented in different forms, indicating variability in how momentum questions may be framed.
superdave
Okay, I did this problem, and my answer disagrees with the book.
A 15.0 g rubber bullet hits a wall with a speed of 150 m/s. It bounces straight back with a speed of 120 m/s. what is the change in momentum?
I get:
delta p=(m*v-i) - (m*v-f)
delta p= (15.0g * 150 m/s) - (15.0 g - 120 m/s) = 15.0 g(150m/s - 120 m/s) = 15.0g * 30 m/s
delta p = 450g * m/s = .45 kg * m/s
the book says the answer is 4.05 kg * m/s
Am I wrong?
Yes. Momentum involves direction as well.
But that doesn't actually answer my concern. It's the magnitude that disagrees.
Oops, now I see why.
I get:
05 kg * m/s
Am I wrong?
Well, if you look at it vectorally... I usually assume that going away from the wall will be positive and going towards the wall is negative.
So the final momentum minus the initial moment will be your answer.
A shortcut (I prefer) is that the mass is 'constant' for this system so all we see is a change in the velocity.
The change in the velocity is NOT 30 m/s, it is in fact 270 m/s.
So 270 m/s * .015 kg = 4.05 N*s (Newtons per second)
Beware that you might also get this question in many forms with momentum... They try to trick you :-P
  • · Replies 19 ·
  • · Replies 31 ·
  • · Replies 16 ·
