| Thread Closed |
Static Magnetic Field and Work |
Share Thread | Thread Tools |
| Mar30-06, 06:28 PM | #1 |
Why can't a static magnetic field (not changing in time) ever do work? How do I express this formulaically? My only guess is that work is zero for a closed path.
| Mar30-06, 06:36 PM | #2 |
Recognitions:
The force on a charged particle in a magnetic field is [tex] \vec{F} = q \vec{v} \times \vec{B} [/tex], right? Stare at that formula for a bit. Now ask yourself, how is the force related to the velocity? Then ask, how is work related to force?
| Mar30-06, 07:07 PM | #3 |
I see, then dv/dt is 0 when the B field is static, so if a=0 then F=0 then W=0. Sound right?
Unfortunately this was on our last exam, and my answer was that W=qV and induced voltage is only a result of B flux changing in time. |
| Mar30-06, 07:16 PM | #4 |
Recognitions:
Wait, how did you conclude that [tex] \frac{d\vec{v}}{dt} = 0 [/tex]? The acceleration certainly isn't zero, there is a force acting.
| Mar30-06, 07:37 PM | #5 |
Is it that the force is perpendicular to the magnetic field and work must be parallel to the displacement?
| Mar30-06, 07:47 PM | #6 |
Recognitions:
You are so close! The force is perpendicular to the field, but that's not what matters. What else is the force perpendicular to?
| Mar30-06, 07:54 PM | #7 |
Ah, so because the force is perpendicular to the velocity, the force is perpendicular to the displacement.
| Mar30-06, 07:59 PM | #8 |
Recognitions:
Indeed. In simple terms, the power [tex] \vec{F} \cdot \vec{v} [/tex] is identically zero. Hence no work is done.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Static Magnetic Field and Work
| pop quiz - electron magnetic field - dynamic or static | Classical Physics | 3 | ||
| the magnetic field and work | General Physics | 5 | ||
| Static Magnetic Field Theory | Introductory Physics Homework | 0 | ||
| work done by magnetic field | Classical Physics | 31 | ||
| Work done by magnetic field... | Classical Physics | 17 | ||
