Mathematical representation and its implication in physics.
This discussion focuses on the implications of using different mathematical representations, specifically quaternions and complex numbers, in physics. It establishes that while both can represent physical theories, their non-commutative and commutative properties respectively can lead to different experimental predictions. The conversation emphasizes that a physical theory's validity is determined by experimental evidence rather than mathematical elegance. It concludes that if both representations yield equivalent experimental outcomes, they can be considered interchangeable.
  • Understanding of quaternions and their properties
  • Familiarity with complex numbers and their applications in physics
  • Knowledge of experimental evidence in validating physical theories
  • Basic concepts of mathematical equivalence and isomorphism
  • Explore the role of quaternions in quantum mechanics
  • Investigate the use of matrices of complex numbers in non-commutative physics
  • Study the implications of Ockham's Razor in scientific theory selection
  • Learn about mathematical isomorphisms and their significance in physics
Physicists, mathematicians, and students interested in the foundational aspects of mathematical representations in physical theories.
MathematicalPhysicist
my post i really about discussing the difference that a mathematical representation does to physics.
for example, let's take for example a system which can be be represented by quaternions and by complex numbers.
if we can represent a physical theory by quaternions which aren't commutative as oppose to complex numbers, does it have an impact on the theory itself?
or in other words we can represent a physical theory by distinct mathematical appraoches which aren't the same and in someway even contrdict each other, then which representation should we approve?
does ockham's razor should put to the test here?
It had better not! A physical theory stands or falls by its experimental evidence. If using one mathematical model rather than another results in a change in experemental evidence then one model was wrong. If neither model suggests an experiment that the other would fail, then they have no differential effect on the theory and are equivalent models.
If the complex numbers, as such, are adequate to describe the physical system, then quaternions cannot be appropriate, precisely because the physics must obey the commutative law in order to be satisfactorally represented by the complex numbers, in the sense that calculations with them can reproduce what happens in experiments. The quaternions, with their non-commutativity, would predict a different set of outcomes.
Now this is complicated because you can represent non-commutative physics using either quaternions or matrices of complex numbers. But those matrices are non-commutative among themselves, and in fact there is a mathematical equivalence (isomorphism) between the quaternions and certain matrices of complex numbers, so no contradiction arises.
  • · Replies 22 ·
  • · Replies 93 ·
  • · Replies 27 ·
  • · Replies 17 ·
  • · Replies 28 ·
