| Thread Closed |
Differential equation problems.... |
Share Thread |
| Apr4-06, 06:46 PM | #1 |
Hey everyone,
Having some problems with these differential equations. If someone could point me in the right direction I would be really grateful. 1) dy/dx=(5x+12y)/3x with initial conditions y(1)=5. I know this is a seperable equation but I'm not sure of the correct algebra to seperate them. Do I make it 5x/3x +12y/3x and then work from there?? 2) dx/dt+3x=cos(2t) x(0)=-1 I know this one is a first order linear differential equation so it must be in the form dx/dt+p(x)y=q(x) and then you take e^(integral)p(x) and so on. I'm not sure what to do since there is no p(x) (or is it just 3??? integral being 3x). I tried that but I have trouble with the integration by parts that results. If anyone could give me some advice or point me in the right direction that would be great. Thanks |
| Apr4-06, 07:34 PM | #2 |
dx/dt+ p(t)x= q(t). And then, Yes, p(t)= 3. [tex]\int e^{3t}cos(2t)dt[/tex] requires integration by parts twice and then think!! |
| Apr5-06, 12:28 PM | #3 |
well if the first one is not seperable then I don't know of a way to solve it. Could you give me a hint. Thanks for the help by the way.
| Apr5-06, 12:48 PM | #4 |
Here's some help for the 1st differential equation...
Some algebraic manipulation will give you the expression [tex] \frac{dy}{dx} - \frac{4}{x} y = \frac{5}{3} [/tex] Do you know how to solve it now? All the best! |
| Apr5-06, 12:48 PM | #5 |
The first is, in fact, separable, if you make a change of variables:
[tex]\frac{dy}{dx}=\frac{5x+12y}{3x}=\frac{5}{3}+4\frac{y}{x}=f(\frac{y}{x})[/tex] Introduce the variable: [tex]u=\frac{y}{x}\to\frac{du}{dx}=\frac{\frac{dy}{dx}-u}{x}\to\frac{1}{(f(u)-u)}\frac{du}{dx}=\frac{1}{x}[/tex] In this case, of course, we have: [itex]\frac{dy}{dx}=f(u)=\frac{5}{3}+4u[/itex] |
| Thread Closed |
Similar discussions for: Differential equation problems....
| Solving a partial differential equation (Helmholtz equation) | Differential Equations | 7 | ||
| Some Differential equation problems | Introductory Physics Homework | 1 | ||
| Differential equation problems | Differential Equations | 0 | ||
| Two Differential Equation Problems | Calculus & Beyond Homework | 2 | ||
| Two Differential Equation Problems | Introductory Physics Homework | 2 | ||
