Solving for a variable inside a sin()
  • Context: Undergrad
  • Thread starter Thread starter Crusty
    Sin Variable
The discussion revolves around solving for a variable \( x \) within the context of a sine function, specifically in the equation \( \sin( \text{degtorad}( (180 - (180 - 360/x))/2 ) ) = y/z \). Participants explore various mathematical properties and transformations related to sine and cosine functions.
  • One participant suggests eliminating the 180's using properties of sine, noting that \( \sin(180 + x) = -\sin x \) and \( \sin(90 + x) = \cos(x) \).
  • Another participant rewrites the original equation, simplifying it step by step, ultimately expressing it as \( \sin(180/x) = y/z \).
  • A different participant points out that \( \sin( (180 - 360/x) /2 ) \) can be transformed into \( \cos(180/x) \) and questions the familiarity with the arccos function.
  • One participant explains the definitions and properties of arcsin and arccos, emphasizing the caution needed due to the non-one-to-one nature of sine and cosine functions.
Participants present various transformations and interpretations of the sine function, but there is no consensus on a definitive method for solving for \( x \). Multiple approaches and viewpoints remain in the discussion.
Some assumptions about the values of \( y \) and \( z \) are not clarified, and the discussion does not resolve the mathematical steps needed to isolate \( x \). The transformations depend on the properties of sine and cosine, which may vary based on the specific context of the problem.
Crusty
sin( degtorad( (180 - (180 - 360/x))/2 ) ) = y/z
degtorad(degrees) means the the degrees inside the parenthesis are converted to radians.
How do you solve for x?
Thank you.
Mathematics news on Phys.org
you can eliminate the 180's by using properties of sine
sin (180+ x) = -sin x = sin(-x)
also,
sin(90+x) = cos(x)
Is this right?
sin( (180 - (180 - 360/x))/2 )
= sin( ( (180 - 360/x))/2 )
= sin( (180 - 360/x) /2 )
= sin( ( 360/x) /2 )
= sin( ( 180/x) )
= sin( 180/x )
sin( 180/x ) = y/z
um, then what?
sin( (180 - 360/x) /2 ) = sin (90 - 180/x) = cos(-180/x) = cos (180/x)
Are you familiar with arccos (or cos^{-1})?
By the way, what exactly are y and z?
Shorn of all the other things, arcsin( ) (also written sin-1( )) is defined as the inverse of sin( ) and arccos() (also written cos-1( )) is defined as the inverse of cos( ) (well, principal value). That is, arcsin(sin(x))= x and arccos(cos(x))= x.
You have to be a bit careful about that: since sin(x) and cos(x) are not "one-to-one" they don't have inverses, strictly speaking. Given an x between -1 and 1, there exist an infinite number of y such that sin(y)= x or cos(y)= x. Arcsin(x) always gives the value, y, between -pi/2 and pi/2 such that sin(y)= x and arccos(x) always gives the value, y, between 0 and pi such that cos(y)= x.
