Integral t = tan(x/2) substitution
The discussion revolves around the integration of a function involving trigonometric terms, specifically using the substitution \( t = \tan(x/2) \). Participants explore the transformation of the integral and the subsequent simplification of the resulting expression.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to apply the \( t = \tan(x/2) \) substitution but expresses uncertainty about the next steps after simplification. Some participants suggest using partial fractions for the integral, while others question the correctness of the transformed expression. Alternative methods of integration are also proposed, including a different approach that avoids substitution.
The discussion is ongoing, with participants providing insights and alternative methods. Some guidance has been offered regarding the use of partial fractions and the exploration of different integration techniques. There is no explicit consensus on the best approach, and participants continue to question and verify each other's work.
Participants note potential typos and errors in expressions, indicating a need for careful verification of calculations. The discussion also highlights the complexity of returning to the original variable after substitution, suggesting that simplification may be challenging.
G01
[tex]\int \frac{dx}{5 - 3\sin x + 4 cos x}[/tex]
I know I have to use t = tan(x/2) substitution, and after i do that and symplify I get:
[tex]\int \frac{dt}{2t^2 - 3t + 1}[/tex]
I don't know where to go from here. If anyone can see where to go, please help. Also, if there is an easier way to do this, please tell me! Thanks.
One of your integral techniques is specifically for integrating fractions with polynomials in the denominator...
Sry that second integral had a 1 in the denominator instead of a 2. And that six is supposed to be a 3. I guess your saying partial fractions will work. I'll try it
ok i got an answer.
[tex]| \ln \frac{\tan(x/2) - 1}{2\tan(x/2) - 1)^2} + C[/tex]
This seems reasonable. If anyone can find a mistake, please tell me. Thanks for the help.
Hrm, there's a typo in your answer somewhere. Anyways, can that be simplified? The integrator at wolfram gives an answer without any logs in it.
Reply
Hmm, I think there is something wrong with your expression [tex]\int \frac{dt}{2t^2 - 3t + 1}[/tex]
I tried doing the substitution myself and the expression in the denominator was a "perfect square".
Maybe you can show us how you did the substitution, or you can try checking your work again...
There is another neat way to go about it. The integration becomes easy, but the trig simplification (if desired) is slightly messy. Don't make a substitution in the first step, simply observe that (-3sin x + 4cos x) = 5cos(x+arctan(3/4)).
Then the integrand can be simplified to 1/5*{1/[1 + cos(x+arctan(3/4))]}, use half angle formulae to get that to a sec^2() expression, which can be integrated immediately to a tan() expression. This is a tangent of a half angle expression, and simplifying this can be slightly (not overly) messy.
But honestly, even after doing the initial substitution with the half angle tangent formula, getting it all back in terms of x is going to be messy anyway. So the way I describe is just as good.
  • · Replies 22 ·
  • · Replies 105 ·
13K
