Starting point not defined for contour integrals?
  • Context: Graduate
  • Thread starter Thread starter chocok
    Integrals Point
The discussion centers on evaluating the contour integral of the function z^(1/2) dz over the contour C1, which spans from z=-3 to z=3. The integrand is piecewise continuous on C1, but the branch of z^(1/2) is not defined on the ray x=0, necessitating the use of an alternative branch defined as f(z) = r^(1/2)exp(ix/2) for -pi/2 < x < 3pi/2. The choice of this new branch is dictated by the requirement that it must define the square root at z=3 and remain compatible with the original branch in a nonempty open set.
  • Understanding of complex analysis, particularly contour integration.
  • Familiarity with branch cuts and multi-valued functions in complex functions.
  • Knowledge of the Cauchy integral theorem and its limitations regarding non-holomorphic points.
  • Basic concepts of manifold theory as it relates to complex functions.
  • Study the properties of branch cuts in complex analysis.
  • Learn about the Cauchy integral theorem and its applications in complex integrals.
  • Explore the concept of multi-valued functions and their branches in complex analysis.
  • Investigate manifold theory and its relevance to complex function transitions.
Mathematicians, students of complex analysis, and anyone involved in evaluating contour integrals and understanding the implications of branch cuts in complex functions.
chocok
I was asked to use antiderivative to evaluate the integral of z^(1/2) dz , over contour C1. for which the intergrand is the branch z^(1/2) = r^(1/2)exp(ix/2) , (r>0, 0<x<2*pi) and C1 is the contour from z=-3 to z=3.
The books says the integrand is piecewise continuous on C1 and integral exist there but the branch of z^(1/2) is not defined on the ray x=0 (or pt z=3). And so we have to integrate it over another branch
f(z) = r^(1/2)exp(ix/2) , (r>0, -pi/2<x<3*pi/2)
I don't really understand why the branch is not defined at x=0.
and also, why do we choose -pi/2 to 3pi/2 as our new range for the branch? How do we determine that?
thanks a lot!
As you know, the square root has two branches in the real numbers: the positive roots and the negative roots. Positive roots and negative roots are separated by the square root at x=0, which is the ramification point. You can prolongate any branch of the square root to x=0, just defining [tex]\sqrt{0} = 0[/tex], which is consistent, but that prolongation won't be differentiable at x=0.
In the complex plane, something similar happens. If you take any branch of the square root and prolongate it as much as you can, you'll eventually find that you can define the branch everywhere except in a ray starting at x=0. This ray determines which branch are you taking. For example, you used two branches in your post: z^(1/2) = r^(1/2)exp(ix/2) , (r>0, 0<x<2*pi), which ray is [tex]\mathrm{arg}(z) = 0[/tex], and f(z) = r^(1/2)exp(ix/2) , (r>0, -pi/2<x<3*pi/2), which ray is [tex]\mathrm{arg}(z) = -\pi/2[/tex].
As in the real case, you may extend any branch to z=0, defining [tex]\sqrt{0} = 0[/tex], but the problem is that in z=0 the square root is not differentiable. That means that in z=0 the square root is not holomorphic, hence you can't take much advantage of path integrals containing z=0.
So the book is somewhat wrong: you can indeed take the square root of z=0, but you can't integrate over it using Cauchy theorem (for example). Your paths must turn around z=0.
The second branch is chosen using two conditions:
1) The new branch must define que square root of z=3.
2) The new branch must be compatible with the first one in a nonempty open set.
This may seem complicated. The idea is that any branch of the square root that you take is good, save the branch with range -pi to pi, which does not verify 2).
The problem is that C1 has as ending point z=3, which is in the undefined ray of your branch with range (0,2pi). So you need another branch of the square root to complete the integral. And your new branch must be coincident with the old one somewhere, so you can compute the transition from one to the other. If you are familiar with manifold theory, the problem can be translated as the need of another chart to carry out the calculation.
I hope this explanations helps.
  • · Replies 19 ·
