| Thread Closed |
energy conservation in interference phenomenon |
Share Thread | Thread Tools |
| Apr6-06, 11:32 PM | #1 |
If on a taut string, we have a wave pulse travelling in the positive x direction with an amplitude A.... simultaneously, from the other end we have a wave pulse travelling in the negative x direction with amplitude -A (i.e., it is faced downwards)
At a certain time t, they will superimpose upon eachother, and if we take a photograph at that time, we will see a straight string, with no wave pulses in it. What has happened to the energy of the two wave pulses? where did it go? |
| Apr7-06, 12:04 AM | #2 |
Where does energy go when you compress a spring? Does it magically disappear?
| Apr7-06, 12:33 AM | #3 |
Recognitions:
AM |
| Apr9-06, 12:19 AM | #4 |
when the string is compressed, the energy is stored as the potential energy of the string.
Andrew, i know... rather feel that there is something wrong in that statement, however i am not being able to explain it mathematically... could you please elaborate? The only force acting in this system is tension... the energy is stored as the potential energy of "tension"? then.. is the tension in the flat portion of the string different? |
| Apr9-06, 06:12 PM | #5 |
Recognitions:
I am pretty confident this is what Andrew Mason had in mind with his comment. Patrick Patrick |
| Apr10-06, 07:08 AM | #6 |
Mentor
There is a terrific article in AJP a couple of years ago on this issue. You may want to look at it.
N. Gauthier "What happens to energy and momentum when two oppositely-moving wave pulses overlap?", Am. J. Phys. v.71, p.787 (2003). Don't miss the followup comment by D. Rowland that corrected the treatment on longitudinal wave. D.R. Rowland, Am. J. Phys. v.72, p.1425 (2004). Zz. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: energy conservation in interference phenomenon
| conservation of momentum vs conservation of kinetic energy | Introductory Physics Homework | 18 | ||
| Energy conservation in wave interference.... | General Physics | 7 | ||
| Simulatenous Conservation of Momentum and Conservation of Energy | Engineering Systems & Design | 9 | ||
| Wave interference and energy conservation | Classical Physics | 1 | ||
| Conservation of energy or conservation of momentum | Introductory Physics Homework | 2 | ||
