Project which involve a falling water droplet
  • Context: Undergrad
  • Thread starter Thread starter blue_moon
    Falling Project Water
The discussion focuses on calculating droplet size for a project involving falling water droplets on dry and wet surfaces. Key parameters include needle diameter and water surface tension, specifically noting that water at 20°C has a surface tension of 72.8 dynes/cm. The relationship between droplet detachment and the balance of gravitational force and surface tension is highlighted, referencing specific equations from a thesis. Resources such as Microdrop and a thesis document are provided for further exploration of the topic.
  • Understanding of surface tension and its measurement
  • Knowledge of droplet dynamics and capillary action
  • Familiarity with basic physics concepts related to gravity and force balance
  • Ability to interpret scientific equations and derivations
  • Research the derivation of droplet size equations from surface tension and needle diameter
  • Explore the Microdrop tool for practical applications in droplet analysis
  • Study the principles of capillary action and its effects on droplet formation
  • Investigate the impact of varying surface tensions on droplet behavior on different surfaces
Researchers, physicists, and engineers involved in fluid dynamics, particularly those studying droplet behavior in various environments.
blue_moon
I am working on this project which involve a falling water droplet on both dry and wet surfaces to figure out how is the splash is going to affect the water separation however, I have to find out the droplet size providing this info
1) Needle diameter
2) Water tension
please help , if there is any derivation or formula that includes the tension and the needle diameter or whatever would help solving this problem?
thanks in advance,
Blue
I founf this I am stuck I have no Idea how to get the droplet size or diameter from the relation below :
for the droplet to detach from the needle tip, gravity has to overcome the surface
tension. so when mg exceeds the interfacial tension at the release point the drop will
fall.
the interfacial tension is: surface tension x 2*pi*r where r is the needle radius.
Water at 20°C has a surface tension of 72.8 dynes/cm...
