Matrix of a linear transformation
The discussion revolves around finding the matrix of a linear transformation T between polynomial space P2 and R2, and verifying a theorem involving transformations between different vector spaces. The original poster presents specific transformations and bases, and raises questions about the computations and interpretations of the matrices involved.
  • Mixed
  • The original poster attempts to compute the matrix representation of T and questions the interpretation of C_D[T(v)] and its relation to T(v). They express confusion about the dimensions of the matrices and the consistency of their formation.
  • Some participants question the definitions and assumptions regarding the coordinate representations and the bases used in the transformations.
  • Others suggest clarifying the types of elements involved in the equations and the meaning of the matrices being formed.
The discussion is ongoing, with participants exploring different interpretations of the matrix representations and questioning the original poster's approach. Some guidance has been offered regarding the definitions of the matrices and the need for consistency in their formation.
There are indications of potential misunderstandings regarding the bases and the dimensions of the matrices involved, as well as the specific transformations being applied. The original poster's computations may not align with the expected definitions and conventions in linear algebra.
stunner5000pt
This is how the question appears in my textbook
Find the matrix of T corresponding to the bases B and D and use it to compute [itex]C_{D}[T(v)][/itex] and hence T(v)
T; P2 - > R2
T(a + bx + cx^2) = (a+b,c)
B={1,x,x^2}
D={(1,-1),(1,1)}
v = a + bx + cx^2
ok i cna find Cd no problem it is
[tex]C_{D}[T(v)] = \frac{1}{2} \left(\begin{array}{ccc} 1&1&-1 \\ 1&1&1 \end{array}\right)[/tex]
now am i supposed to solve for X where
[tex]C_{D}[T(v)] X = T(v)[/tex]
but textbook doesn't do that...
it does [tex]C_{D}[T(v)] \left(\begin{array}{c} a \\ b \\ c \end{array}\right) = X[/tex]
It doesn't make sense... doesn't the question ask to compute Cd[T(v)] and T(v) from it??
Next question
Verify this theorem for the given transformation and uses the standard basis in Rn
Theorem:
[itex]M_{EB} (ST) = M_{ED} (S) \bullet M_{DB} (T)[/itex]
T;R3 -> R4
S: R4->R2
T(a,b,c) = (a+b,b+c,c+a,b-a)
S(a,b,c,d) = (a+b,c-d)
[tex]M_{EB} (S) = \left[C_{D}\left(\begin{array}{c} 1 \\ 0 \end{array}\right) \ C_{D}\left(\begin{array}{c} 1 \\ 0 \end{array}\right) \ C_{D}\left(\begin{array}{c} 0 \\ 1 \end{array}\right) \<br /> C_{D}\left(\begin{array}{c} 0 \\ -1 \end{array}\right)\right][/tex]
[tex]M_{EB} (S) = \left[\begin{array}{cc} 1&0 \\ 1&0 \\ 0&1 \\ 0&-1 \end{array}\right][/tex]
[tex]M_{DB} (T) = \left[C_{D}\left(\begin{array}{c} 1 \\ 0 \\1 \\ -1 \end{array}\right) \ C_{D}\left(\begin{array}{c} 1 \\ 1 \\ 0 \\ 1 \end{array}\right) \ C_{D}\left(\begin{array}{c} 0 \\ 1 \\ 1 \\ 0 \end{array}\right)\right][/tex]
[tex]M_{DB} (T) = \left[\begin{array}{cccc} 1&0&1&-1 \\ 1&1&0&1 \\ 0&1&1&0 \end{array}\right][/tex]
the dimensions of the matrices are not correct though..
is there something wrong in the way i am forming the matrices?
What does [itex]C_D[T(v)][/itex] mean?
First off, did you notice that T(v) is a vector in R²?
I think it might help you a great deal to write down explicitly exactly what type everything is in your equations. E.G. you might write down:
v : element of P2
T : transformation from P2 --> R²
T(v) : element of R²
[itex]C_D[T(v)][/itex] : 2x1 matrix.
I'm going to assume [itex]C_D[w][/itex] means the coordinate representation of the vector w, with respect to the basis D.
So you didn't compute [itex]C_D[T(v)][/itex] at all -- instead, you computed [itex]M_{B,D}[T][/itex] which is the coordinate representation of the linear transformation T, with respect to the bases B and D!
You really ought to go reread the section on coordinates and bases. The whole point of coordinates is that they simply transform the equation into matrices. In other words, the equation:
T(v) = w
is true if and only if the equation
[tex]M_{B,D}[T] \cdot C_B[v] = C_D[w][/tex]
is true.
Well, you're certainly not internally consistent:
First, you wrote down the matrix with three columns, each of which is supposed to be the coordinate representation of a vector in R^4.
And then you wrote down a matrix whose rows are the transpose of those coordinate representations.
Incidentally, based on how the problem's stated, E is the basis on R^4, and D is the basis on R³, so you meant [itex]M_{ED}(S)[/itex] and not [itex]M_{EB}(S)[/itex].
well then what is the different between [itex]M_{ED}(s)[/itex] and [itex]M_{EB}(S)[/itex] is it even possible to form the former?
  • · Replies 18 ·
