Solving Water Pressure Problems: Guidance for Parts B and C
The discussion revolves around a fluid dynamics problem involving water pressure in a pipe system. The problem specifically addresses the pressure at various points in the system and the exit speed of water from the pipe, utilizing Bernoulli's principle and the properties of an ideal fluid.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to apply Bernoulli's equation to find pressures and velocities at different points in the system. Some are questioning how to derive the velocity and pressure at specific points, particularly under the 4m opening. Others are exploring the relationship between the areas and velocities of the pipe and exit opening.
There are multiple interpretations being explored regarding the application of Bernoulli's principle. Some participants have made progress in calculating pressures, while others are still seeking clarification on how to set up the equations correctly for parts b and c. Guidance has been offered regarding the use of Bernoulli's equation, but no consensus has been reached on the specific setup for the calculations.
Participants are working within the constraints of the problem, including the assumption of ideal fluid behavior and the specific heights and areas given in the problem statement. There is an acknowledgment of the atmospheric pressure and its role in the calculations.
kellyneedshelp
Could anyone offer me some guidance on parts b and c of the following question?
The pressure in a uniform pipe of flowing water is enough to hold up 4.00 m of water in an open, vertical tube as shown in Figure P.60. Assume that water is an ideal fluid. The pipe leads 3.00 m upstairs and empties into the open air through an opening with an area one-fourth that of the uniform pipe.
(a) At the exit opening of the pipe, what is the pressure?
(b) What is the pressure at the point where the vertical tube is connected to the pipe?
(c) What is the exit speed of the water from the pipe?
this is the picture of the problem:
http://img346.imageshack.us/img346/5326/p11607ht.gif"
for part (a), i figured b/c the water is open to the air, its pressure is 1 atm (approx. 1.01E5 Pa).
for parts (b) and (c), i think i need to somehow use the equation:
P1 + (1/2)*density*v1^2 + density*g*y1 = P2 + (1/2)*density*v2^2 + density*g*y2
but I'm not sure how to get the velocity or pressure at the point under the 4m opening.
any ideas/hints for me?
thanks!
i figured this one out, looks like i was on the right track afterall!
I am doing this exact same problem and am also unsure of how to use Bernoulli's principle for b) and c).
Help please.
Pressure P1 = Pa + rho*g*h where Pa atmospheric pressure, rho is the density of water and h = 4m. P2 = Pa
I've gotten the pressure at the opening= P(atmosphere)
I've gotten the pressure under the 4 m opening= 140565=P(atmosphere)+1000(9.81)(4 m)
What is the exit speed of the water from the pipe?? In my case,
The pipe leads 3.00 m upstairs and empties into the open air through an opening with an area one-third that of the uniform pipe."
so we know that A1v1=A2v2 so A1v1=1/3A1v2 and thus 3v1=v2 where v2 is the exit speed and v1=speed in the pipe
how do I set up
Bernoulli's principle to get v1 and thus v2?
  • · Replies 19 ·
