Care to help? Complex mathematical problem
  • Context: Mathematica
  • Thread starter Thread starter mfdoom
    Complex Mathematical
The discussion revolves around the application of digital filters, specifically low pass and high pass filters, in the context of audio signal processing. Participants explore the mathematical foundations and practical implementation of these filters, including the use of MATLAB for filtering tasks.
  • Homework-related
  • One participant seeks help in understanding the circular diagram related to low pass and high pass filters, expressing confusion about the transition from low pass to high pass filtering.
  • Another participant points out a miscalculation regarding the conversion of frequency units and questions the polynomial form being used for the filters, suggesting that it may not align with standard forms.
  • A participant clarifies their understanding of the frequency range relevant to their audio mixing project and expresses uncertainty about the order of the filters, noting that a 2nd order filter would provide a faster roll-off.
  • Discussion includes the importance of filter order and topology (e.g., Butterworth, Chebychev) in determining filter characteristics, with a focus on the implications for digital filtering.
  • One participant mentions their experience with MATLAB's FILTER function and provides details about its implementation, indicating a reliance on external help for understanding the polynomial aspects.
  • Another participant inquires about the sample frequency of the digitized signal, emphasizing its relevance to the filtering process.
  • There is mention of a textbook that may assist in understanding digital filter design, suggesting that participants are seeking additional resources for clarity.
Participants express varying levels of understanding regarding the mathematical aspects of filter design and implementation. There is no consensus on the specific polynomial forms or the best approach to take for the high pass filter, indicating that multiple competing views remain.
Participants have not fully resolved the mathematical steps involved in filter design, and there are dependencies on definitions and assumptions related to filter order and topology. The discussion also reflects uncertainty regarding the transition from low pass to high pass filtering.
mfdoom
Hi, I am trying to apply the filter and I have the values for the low
pass filter and the working out, but the thing is I had a bit of help
with it so I don't quite understand the circular diagram here:
http://i36.photobucket.com/albums/e18/ocundale/untitled.gif
(you will need to make the image full size to see it properly)
The thing is I need to find values for the high pass filter now and I no longer have the help of my friend, so I was wondering whether anyone could help me out with understanding the circle complex theory of it, as I
don't fully understand it and I need to get the values to plug into
Matlab.
I have trawled the net for information, but none of it has really
helped me in understanding it. What I understand is in the image, but
I don't know how to do the high pass filter, I just know that I can't
do it the same way as I worked out values for the LPF.
Thanks for your time!
Oli
Well, first of all, 150Hz is not 0.98 radians/second. I'm not really sure what you are doing in your work. You are correct to make the bandpass filter by cascading a LPF and HPF, as long as the two frequencies are far enough apart. 150Hz = 3x 50Hz, so in this problem they are a little close, but it's probably okay for your homework problem.
I also don't understand the H(z) polynomial form that you are starting with -- that's not the standard form for a LPF or HPF. Do you know what H(z) is for the LPF and HPF? It looks like you are asked to make each of the two filters 2nd order -- is that correct?
Thanks for the quick response berkeman, firstly, I mis-typed the bit which says 0.98 rads, sorry about that - its actually 0.02, I have updated the pic. Between 50Hz and 150Hz is where the bass lies in the tracks I will be mixing and I can easily determine the BPM by finding the peaks in amplitude in this frequency range, but first I need to take out all the other frequencies.
I am not sure about what order the filter is, I understand that 2nd order would drop off faster, so I guess that would be fine.
I am not too sure about the H(z) polynomial form, as that is the bit my friend helped me out with, but here is the info from the help on Matlab:
FILTER One-dimensional digital filter.
Y = FILTER(B,A,X) filters the data in vector X with the
filter described by vectors A and B to create the filtered
data Y. The filter is a "Direct Form II Transposed"
implementation of the standard difference equation:
a(1)*y(n) = b(1)*x(n) + b(2)*x(n-1) + ... + b(nb+1)*x(n-nb)
- a(2)*y(n-1) - ... - a(na+1)*y(n-na)
If a(1) is not equal to 1, FILTER normalizes the filter
coefficients by a(1).
FILTER always operates along the first non-singleton dimension,
namely dimension 1 for column vectors and non-trivial matrices,
and dimension 2 for row vectors.
[Y,Zf] = FILTER(B,A,X,Zi) gives access to initial and final
conditions, Zi and Zf, of the delays. Zi is a vector of length
MAX(LENGTH(A),LENGTH(B))-1, or an array with the leading dimension
of size MAX(LENGTH(A),LENGTH(B))-1 and with remaining dimensions
matching those of X.
FILTER(B,A,X,[],DIM) or FILTER(B,A,X,Zi,DIM) operates along the
dimension DIM.
See also FILTER2 and, in the Signal Processing Toolbox, FILTFILT.
0.02 radians per second is a very low frequency.
So it sounds more now like you are working totally in the digital domain, with no analog filtering involved in this project? What is the sample frequency of the signal digitization?
You need to chose the order of your filters and the topology of the filters (Butterworth, Chebychev, Elliptical) before you can work with the polynomials. The order is what gives you the steepness of the rolloffs, and the polynomial type is what determines the flatness of the passband versus some other characteristics.
Do you have a textbook on analog or digital filters? What is the project exactly? I've found the textbook by Williams on "Designing Digital Filters" to be extremely helpful. Maybe see if your school library has a copy...
Yes, I am just working in the digital doman, the sample frequency is 44100 and the LPF I have made with the help of my friend works fine. I have ordered a book on digital processing just now, so hopefully that'll help me a lot.
  • · Replies 20 ·
11K
  • · Replies 80 ·
9K
