Why Must We Contract Two Indices to Form the Ricci Tensor?
  • Context: Graduate
  • Thread starter Thread starter Oxymoron
    Ricci tensor Tensor
The discussion revolves around the process of contracting indices in the Riemann curvature tensor to form the Ricci tensor on a pseudo-Riemannian manifold. Participants explore the implications of contracting two indices versus one, questioning the necessity and outcomes of different contraction methods.
  • Some participants explain that contracting the Riemann curvature tensor involves summing over two indices to produce a (2-0)-tensor, questioning why one cannot contract a single index instead.
  • One participant suggests trying to define a "trace" operation on a vector space to illustrate the invariance under change of basis, implying that a scalar result should be invariant.
  • Another participant expresses uncertainty about the meaning of "trace" and questions whether summing components of a vector yields a scalar that is invariant under basis changes.
  • Some participants argue that changing the basis can affect the sum of components, potentially leading to different results, including zero.
  • One participant discusses the specific contractions of the Riemann tensor, noting that certain contractions yield zero while others do not, linking this to the Bianchi identities.
  • Another participant emphasizes that the metric of the manifold is crucial for contracting indices, as it allows for the inner product necessary for such operations.
  • There is a discussion about the notation used in defining the Riemann tensor and the implications of raising and lowering indices in the context of contractions.
  • One participant asserts that the only way to obtain a (0-3)-tensor would require a covariant vector, which would alter the tensor's argument structure.
Participants express differing views on the implications of contracting one versus two indices, with no consensus reached on the necessity or outcomes of these operations. The discussion remains unresolved regarding the broader implications of these contractions.
Some limitations are noted regarding the assumptions about the invariance of operations under basis changes and the specific roles of the metric in the contraction process. The discussion also highlights potential confusion around notation and index placement.
Oxymoron
Producing the Ricci tensor
On a pseudo-Riemannian manifold we can contract the Riemann curvature tensor to form the Ricci tensor. In this process of contraction we sum over two indices to make a (3-1)-tensor into a (2-0)-tensor. My question is, why must we contract two indices? Why can't we contract one index to form a (3-0)-tensor or a (2-1)-tensor, etc...
Try it. Use your favorite vector space... say, R². You could use R and it will be even more obvious.
Anyways, try and define a "trace" operation that takes a (1,0)-tensor (that is, a vector in your vector space), and produces a (0,0)-tensor (that is, a scalar).
Oh, and don't forget it should be invariant under change of basis! So...
if Tr(v) = r
then if we apply the change of basis on V given by the transformation A...
then Tr(Av) = r
(because a change of basis doesn't affect scalars)
Im not sure what "trace" means, but if I sum the components of my vector I get a scalar. ??
Is this operation invariant under a change of basis?
Incidentally, that could be achieved by contracting the tensor product of your vector with a particular covector... so it's nothing new! (And as a benefit, the resulting operation will be invariant under a change of basis... although in other bases it doesn't look like simply adding the components of your vector)
I believe that it is not. Changing the basis means the sum will change. In fact, I could change the basis so that the sum is zero, when it was nonzero beforehand.
I may need a hint. :)
Well, my example was supposed to make it clear that there isn't a reasonable way to do it. :smile:
Also, note that any linear map from V to R is given by simply applying a covector (or equivalently, tensoring with a covector then contracting) -- so we already have all possible such maps in our algebra!
Sorry Hurkyl, unfortunately, I'm not seeing your point.
Take the Riemann curvature tensor
[tex]R(X,Y,Z,\omega)[/tex]
as we can see, it is a (4-1)-tensor with vector fields in the first three slots and one 1-form in the fourth slot. (I believe alternatively we could write this as
[tex]R(X,Y,Z,V^{\flat})[/tex]
but that is another story)
Anyway, we can write the Ricci tensor as
[tex]Ric(X,Y) = R(X_a,Y,Z,\omega^a)[/tex]
by summing over the first and fourth indices. If we sum over the first two, we get
[tex]R(X_a,Y^a,Z,\omega) = 0[/tex]
why? I am not sure. Likewise, we could sum over the last two:
[tex]R(X,Y,Z_a,\omega^a) = 0[/tex]
and it vanishes again. Again, not sure why.
But, if we sum over the first and fourth say (equivalently we could sum over the second and fourth) we do not get zero, and this time I think I know why - because of the Bianchi identities.
The question I propose: Does contracting over two only work because of the fact that our manifold must have a metric.
I was trying to demonstrate the problem with the notion of "contracting one index" in the case where we were simply working with a vector. The only way to get from a vector to a scalar is to apply a covector. (Though it may be disguised as a more complicated expression)
Anyways, I'm having type issues with your notation.
So you've defined the Riemann tensor as a map that eats three vectors and a covector, and produces a scalar.
That's fine -- you can contract over its first and fourth indices to produce a rank 2 covector. But your notation seems troublesome:
because the contraction applies to the tensor and not the arguments. In the abstract index notation, R is given by [itex]R_{abc}{}^d[/itex], and you've contracted to produce [itex]R_{abc}{}^a[/itex].
And besides, if X is a vector, then its index should be a superscript!.
Summing over the first two indices is just wrong: they're both subscripts! You have to first apply the metric to raise an index: [itex]R^a{}_{bc}{}^d = g^{a\mu} R_{\mu bc}{}^d[/itex], and then you can contract.
So, your hunch was right for this case. The metric is the only reason we can contract over two like indices -- because what we are really doing is taking an inner product.
Anyways, isn't this one of the antisymmetries of the Riemann tensor? That [itex]R_{abc}{}^d = -R_{bac}{}^d[/itex]? Or in the functional notation, R(X, Y, Z, w) = -R(Y, X, Z, w)?
Contraction is an operation between covariant and contravariant indices. The Ricci tensor is formed by the self contraction of the Riemann tensor, and since there is only one contravariant (raised) index there's only one possible type of tensor one can get from self contraction of the Riemann tensor, a (0 2) tensor.
[tex]R^a_{bad}=R_{bd}[/tex]
One could contract on other covariant indices other than the middle one, but this is the only contraction that yields a symmetric (0 2) tensor, and the other possible contractions between contra- and covariant indices can be expressible as this symmetric one.
To get a (0 3) tensor we'd have to supplement a covariant vector on which to operate R on, thus removing this "slot" in the tensor's argument.
[tex]\omega_aR^a_{bad}[/tex]
