Collecting air samples to test for primary pollutants.
  • Thread starter Thread starter Binary Star
    Air Test
The discussion focuses on collecting air samples for testing primary pollutants in a local air quality lab project. The participant seeks advice on appropriate containers for air samples, emphasizing the need for transparency to allow infrared beam analysis. Suggestions include using ziplock bags, although concerns about their effectiveness in distinguishing between different air sources are raised. The participant is encouraged to consider the sensitivity of their infrared equipment before finalizing their sampling method.
  • Understanding of air sampling techniques
  • Knowledge of infrared spectroscopy
  • Familiarity with environmental science principles
  • Experience with laboratory safety protocols
  • Research air sampling methods for environmental analysis
  • Explore the specifications and sensitivity of infrared spectroscopy equipment
  • Investigate suitable transparent containers for air sample collection
  • Learn about the impact of different pollutants on air quality measurements
This discussion is beneficial for environmental science students, researchers in air quality assessment, and anyone involved in laboratory testing of pollutants.
Binary Star
I'm doing a lab (Extended Essay, if you're familiar with the IB program) on the local air quality. I basically would need to collect some air samples to test, but I'm not sure how I would go about collecting appropriate samples of air. I'm also not sure in what sort of container I could place them in.
The container has to be transparent since I will be shooting an infrared beam through the air sample.
So, how could I go about collecting air samples, and what kind of containers do you suggest I get/make? I've got the rest of the lab set-up, but I'm stumped on how I would collect air samples. I guess I could just use ziplock bags and fill them with the 'air' in different areas of the city, but I'm not sure if that'd work. ANY ideas will be greatly appreciated.
Without knowing what time constraints you face, I'll offer a suggestion that you look at the sensitivity of your IR before committing yourself too heavily --- can you distinguish between air you breathe and a ziploc filled from an auto/truck/bus tailpipe?
I have plenty of time ^_^.
I just need to figure out a good way to collect air samples, and a good way to store them so I can test them. I have two ways that I've thought of, and both require a way to store air samples.
  • · Replies 24 ·
