Register to reply
Group Extensions
by calvino
Tags: extensions
Share this thread:
calvino
#1
Apr10-06, 12:25 PM
P: 108
A group G is an extension of A by B (A,B groups) if there exists a normal subgroup of G (call it N) such that A is isomorphic to N, and G/N is isomorphic to B.
Is there a simple way to identify ALL such extensions, if A, B are small groups (order 4 or less would dignify "small"). Simple or not, how is it done? -I've looked throughout the web, and cannot find much on "group extensions".
Furthermore, is there a way to say how many extensions of A by B exist?
I decided to try a simple example (finding as many non-isomorphic extensions of Z_2 by Z_2 (integers mod 2), and obviously theres the Z_2 X Z_2 extension, and there's Z_4 . What other possibilities are there?
Phys.Org News Partner Science news on Phys.org
An interesting glimpse into how future state-of-the-art electronics might work
Tissue regeneration using anti-inflammatory nanomolecules
C2D2 fighting corrosion
Hurkyl
#2
Apr10-06, 12:40 PM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,091
Well, if A is isomorphic to N, and B is isomorphic to G/N, then you know:
|A| = |N|
|B| = |G| / |N|
and so |G| = |A| |B|
which ought to help you in your classification efforts.
Since you've just listed every group of order 4, you've covered all the possibilities.
It might be worthwhile to consider the case where G is abelian (and thus so are A and B), because of the nice structure theorems for abelian groups.
I suspect that if you're really good at this stuff, the finite, abelian case could be solved completely over the course of an afternoon!
Anyways, the programme, I expect, would be to build up the full answer by starting with cyclic groups of prime order, then of prime power order, and then showing how the theory behaves when you take the products of groups.
matt grime
#3
Apr10-06, 02:56 PM
Sci Advisor
HW Helper
P: 9,396
Yes, this theory is completely classified, by group cohomology. The general case is hard to describe, but the cases you mention are easy.
Register to reply
Related Discussions
Isometry sub-group of the gauge group & the center of structural group Differential Geometry 0
Lorentz group, Poincaré group and conformal group Special & General Relativity 12
Group extensions Calculus & Beyond Homework 3
Field extensions Linear & Abstract Algebra 5
Statics and extensions? Introductory Physics Homework 3
