Rotation of rigid bodies: yo-yo
The discussion focuses on calculating the final velocity of a yo-yo consisting of two cylinders with radii R1 and R2, and masses M1 and M2, after falling a height h using Newton's second law. The net force equation applied is Fnet, y = (M1 + M2) - T = (M1 + M2)(a)cm, leading to the moment of inertia calculated as I = 1/2*(M1*R1^2 + M2*R2^2). The derived acceleration formula is a = (M1 + M2)g / ((I/(2R1^2)) + (M1 + M2)), indicating that acceleration is constant. The discussion concludes with the need to relate this constant acceleration to the final velocity after falling a distance h.
  • Understanding of Newton's second law of motion
  • Familiarity with the concepts of moment of inertia
  • Knowledge of rotational dynamics
  • Basic calculus for integration
  • Research the relationship between linear and angular acceleration in rotational systems
  • Learn how to integrate constant acceleration to find final velocity
  • Study the principles of energy conservation in falling objects
  • Explore the dynamics of rigid body rotation and its applications
Physics students, mechanical engineers, and anyone interested in the dynamics of rotating bodies and their motion under gravitational forces.
syang9
consider a yo-yo consisting of two cylinders of radius R1, (combined) mass M1, glued to another smaller cylinder of radius R2, mass M2. find the final velocity after falling a height h using Newton's second law. assume the string is vertical.
the inner radius R2 is R0, the outer radius R1 is R in this picture
so, i started off by applying f = ma to M2..
tnet, ext = T(R1) = I(alpha), alpha = (a)cm/R1
i calculated the moment of inertial to be the sum of the moments of inertia of the cylinders..
solving for (a)cm, i get a very nasty formula..
a = (M1 + M2)g / ( ( I/(2R1^2)) + (M1 + M2))
my original plan was to integrate this wrt time to get a velocity.
but this formula doesn't involve anything that changes with time.. so how do i obtain the final velocity? am i even on the right track?
It looks ok.
As you noticed, the expression for a doesn't involve anything that changes wrt time. In other words, a is constant!
If you had an object that was falling under gravity, what would its velocity be after having fallen a distance h?
So then, what if g = a?
  • · Replies 42 ·
