Understanding the Heat Equation and its Fundamental Solution
  • Thread starter Thread starter FrogPad
    Integral Weird
The discussion revolves around the one-dimensional heat equation, specifically the fundamental solution and its interpretation. Participants are exploring the role of the dummy variable 'y' in the integral representation of the solution and its implications for understanding the heat equation.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are questioning the necessity and origin of the variable 'y' in the integral. Some suggest it is merely a dummy variable that can be replaced without affecting the outcome. Others express confusion about how this relates to the one-dimensional nature of the problem.
There is an active exploration of the concept of dummy variables and their role in integrals. Some participants have provided insights into the nature of the integral and suggested alternative approaches to gain understanding. However, there is no explicit consensus on the overall interpretation of the fundamental solution.
Participants are working within the constraints of a homework assignment, which may limit the depth of exploration. The original poster expresses a desire for more detailed guidance on transitioning from the fundamental solution to specific examples, indicating a potential gap in understanding.
FrogPad
We are now studying the one space dimension heat equation [itex]u_t = u_{xx} [/tex]<br /> <br /> The fundamental solution is given as:<br /> [tex]u(t,x)=\int_{-\infty}^{\infty} \frac{1}{2\sqrt{\pi t}}e^{-(x-y)^2/4t}u_0(y)dy[/tex]<br /> <br /> I don't understand where the [itex]y[/itex] comes from. <br /> <br /> The example in this section is:<br /> If [itex]u_0(x)=1[/itex], the temperature stays at [itex]u =1[/itex] for all [itex]t[/itex].<br /> <br /> I wish I could see the solution, instead of just the answer. But that's the style of the book. I just don't see how to go from the fundamental solution, to the answer.[/itex]
I'm not familiar with the heat equation but in this integral, y is just a dummy variable. You integrate with respect to y (although you can give it any other name, just not t or x to avoid confusion), but the y will vanish in the answer of course.
The y is a dummy variable; it is integrated out. If you want insight into the solution, try some other easily integrable cases. For example, what if u_0 is a delta function? Or try plotting the integrand for a sequence of different y's, then imagine them all added together.
Weird so it's kind of like a loop for the expression contained in the integral?
I'll have to play around with this. It's new to me. (or at least I can't remember doing this before).
If you did integrals in calculus, you used dummy variables:
[tex]\int_0^1 y dy= \frac{1}{2}y^2 \|_0^1= \frac{1}{2}[/itex]<br /> Do you see that there is no "y" in the result? Do you see that it doesn't matter what variable we use?<br /> <br /> If the solution to you differential equation had been given as<br /> [tex]u(t,x)=\int_{-\infty}^{\infty} \frac{1}{2\sqrt{\pi t}}e^{-(x-p)^2/4t}u_0(p)dp[/tex]<br /> or <br /> [tex]u(t,x)=\int_{-\infty}^{\infty} \frac{1}{2\sqrt{\pi t}}e^{-(x-z)^2/4t}u_0(z)dz[/tex]<br /> it would still be exactly the same.[/tex]
Yeah, I see how the 'y' disappears. And understand that it could be anything disappearing. I guess it's just how you "see" the problem sometimes. In the heat equation, the 'y' just seemed to come out of nowhere. I thought the problem only dealt with one spatial dimension, and then one dimension with time to track the temperatures at various locations. Then 'y' was introduced... and I didn't understand why that was even there.
I still have a question though regarding the example given in the book.
So we have:
With BC [itex]u_0(x)=1 [/tex] for all [itex]x[/itex].<br /> <br /> So, when evaluting the integral, [itex]u_0(y)[/itex] from [itex]-\infty[/itex] to [itex]\infty[/itex] will evaluate to 1.<br /> <br /> Thus the fundental solution drops drops down to:<br /> [tex]\frac{1}{2\sqrt{\pi t}} \int_{-\infty}^{\infty} e^{-(x-y)^2/4t}dy[/tex]<br /> <br /> and this is supposed to evalutate to 1 for all t?<br /> <br /> I'm not sure if I'm doing this right. Am I?<br /> <br /> Thanks everyone.[/itex]
Correct.
Change your dummy variable y to u by
[tex]u=\frac{y-x}{2\sqrt{t}}[/tex]
We then have:
[tex]\frac{dy}{du}=2\sqrt{t}[/tex]
whereby your integral becomes:
[tex]\frac{1}{\sqrt{\pi}}\int_{-\infty}^{\infty}e^{-u^{2}}du[/tex]
Cool, thankyou!
Also, I was going to ask. The term "dummy variable"... that's not the "technical" name is it?
