What is the appropriate gain for the MCA amplifier in this scenario?
  • Thread starter Thread starter dagg3r
    Amplifier Gain
The appropriate gain for the MCA amplifier in this scenario is determined to be 2000X, which amplifies a 4.0 mV pulse height to 8 V, achieving 80% of the full scale (10 V). The discussion highlights that the gain selection is critical to avoid off-scale readings, particularly for the higher energy gamma ray at 200 keV. The energy resolution of the system is 20 keV, and the pulse heights for the gamma rays are 1.0 mV and 4.0 mV, with corresponding quantum efficiencies of 100% and 50% respectively.
  • Understanding of MCA (Multi-Channel Analyzer) systems
  • Knowledge of gamma ray detection and pulse height analysis
  • Familiarity with energy resolution calculations in spectroscopy
  • Basic principles of quantum efficiency in detectors
  • Research MCA gain settings and their impact on signal detection
  • Learn about energy resolution calculations in gamma spectroscopy
  • Explore the effects of quantum efficiency on pulse height measurements
  • Investigate the relationship between pulse height and channel number in MCA systems
Physicists, nuclear engineers, and technicians working with gamma spectroscopy and MCA systems, particularly those involved in optimizing signal detection and analysis.
dagg3r
:mad: A radioactive material emits 2 gamma rays with 2 energies 50 keV and 200 keV with equal probabilities the detector system has a quantum efficiency of 100% and 50% respectively at these 2 energies and the pulse heights are 1.0 mV and 4.0mV respectively. The pulses are input into a 512 channel, 10 V lfull scale, MCA. The total system has an energy resolution of 20 keV.
Suggest an appropriate gain of the MCA amplifier
i sketched the displayed spectrum... also looking at the solutions they somehow got a gain of 2*10^3 with the pulse height of 4.0 mV at a channel 409 corrresponding to 8 V.
any ideas how htey got that gain and the channel number corresponding to the pulse height?
i tried fiddling round with the formulas given of
energy resolution = (FWHM / pulse height at centre of peak) * 100%
no luck.. somehow they got a gain of 2*10^3 for a plot that is num of counts vs channel number...
hope you guys know
I don't see why the gain chosen shouldn't just follow from the largest detected signal (4mV) and the FS value (10V). Since the MCA gain on a spectrometer is usually selected on a dial, you have a limited number of options. A gain of 2000X will amplify a 4mV signal to 8V (80% of FS). A higher gain setting (like 4000X or 5000X) would take the high energy peak off-scale.
