Calculating Work Done by a Constant Force
The discussion revolves around calculating the work done by a constant force, specifically in the context of a force diagram and its components. Participants are examining the correctness of a solution related to a physics problem involving force and distance.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster seeks validation of their solution and presents a force diagram. Some participants question the accuracy of the diagram and the representation of force components. There are discussions about the relationship between force, distance, and the calculation of work.
The discussion is active, with participants providing feedback on the original poster's sketches and calculations. Some guidance has been offered regarding the correct representation of force components and the need to clarify the force diagram. Multiple interpretations of the problem setup are being explored.
Participants note potential issues with mixing units in the diagrams, as well as the necessity of accurately representing force components in the context of the problem.
opticaltempest
I have the following problem,
http://img236.imageshack.us/img236/1684/problem7ke.jpg
http://img236.imageshack.us/img236/6213/image8oa.jpg
Is my solution correct?
http://img235.imageshack.us/img235/9374/solution1ez.jpg
Thanks
Your drawing is not right, but your answer is.
AC is not 50 feet, it the x-component of the 25 pounds of force. You computed it correctly with cos(20)*25, and then multiplied it by distance to get work.
I made a few changes to my sketch. How does that look?
http://img92.imageshack.us/img92/4974/100018at.jpg
Thanks
You get the concept, but you're not going to have feet and pounds in the same diagram. You can't add them together. Just get rid of point E. AC is all you need to complete your force diagram. W=F*D. You computed force correctly. You multiplied it by distance and got work. Now just get distance out of your force diagram. It doesn't belong there. If you want, you can draw a separate 1-dimensional diagram showing distance on the x-axis, but that is not necessary. Just get rid of your CE vector and you're finished.
  • · Replies 19 ·
