Circuit Theory: physics vs. convention?
The discussion revolves around the conventions in circuit theory, particularly the flow of current and the implications of these conventions on understanding circuit behavior. Participants express confusion regarding the distinction between conventional current and the actual movement of electrons, as well as the impact of historical choices on current definitions.
  • Participants explore the relationship between conventional current and the actual flow of electrons, questioning how to interpret current direction and its signs. There are inquiries about the implications of using negative charges in current definitions and how this relates to circuit analysis.
Some participants have provided clarifications regarding the definitions of current and the significance of conventions. There is an acknowledgment of the confusion surrounding these concepts, with participants sharing their experiences and seeking reassurance about their understanding.
Participants mention feelings of panic and confusion when faced with circuit details, indicating a need for confirmation of their understanding. There is also a reference to the historical context of current conventions, which some find unsettling.
KCL
This bothers me every time I study circuits, currently introductory level.
I can solve problems just fine, but something is just not "clicking" here. Mostly conventions for things like current, power absorption, etc...
Is there some where an explanation of what actually happens in a circuit and how does it relate to conventions like taking the current to move from positive to negative? I keep staring at a diagram of currents and thinking "is this negative current just the opposite of the positive one 'we use' or the 'real' current of negative charges that's actually moving or or or" etc... :confused:
I don't think I can even phrase the question correctly, I hope someone understood me from this post. :smile:
You can equally well consider current to be positive charges moving in one direction (this is conventional current), or negative charges moving in the opposite direction (this is how electrons actually move).
- Warren
Ben Franklin has often been credited with our convention of current flow from positive to negative poles.
If you want to know which way current is flowing, you can normally find the direction in which electrons are flowing and then reverse it. Life for physicists and electrical engineers would be so much simpler if Benjamin Franklin hadn't made an unfortunate choice that gave electrons--the principal carriers of electricity--a negative electric charge. We have been living with the consequences of that choice ever since.
http://rabi.phys.virginia.edu/HTW/flashlights.html
You're not the first to notice this. Many of us, myself included, found this convention disturbing. Perhaps the only way to change it now would be by international agreement amoung scientists and the technical community. :smile:
- Warren
stupid question:
So if, let's say you're using the actual current - negative charges. Would the current be just 5 amps and a negative of that be the positive one in the opposite direction or would it be -5 amps with the negative of that be the positive one in the opposite direction? :redface:
Thanks for any help.
Current is always defined with respect to some convention. If you assume a direction, and you're right, the value is positive. If you assume a direction, and you're wrong, the value is negative.
Really, forget about the signs on currents, and instead just look at the arrows on the schematics that indicate which direction the currents are flowing.
- Warren
Ok that's exactly what I needed to hear, thanks.
What sort of questions are you having about power absorption?
I was just rambling about everything because current signs/direction just confused everything in any circuit. Once I get "stuck" on any detail I just panic and become incapable of understanding anything, so that really screwed me up for a while. Texts explain it clearly but I just needed to make sure, to read the same thing I'm getting from the text but after I ask a question on it just to confirm that I'm really "getting" it... Not sure if this makes sense. :redface:
And yes I have a serious OCD problem. :smile:
