Question about automotive suspensions
  • Context: Automotive
  • Thread starter Thread starter krekquel
    Automotive
This discussion centers on the relationship between caster angles, steering axis inclination (SAI), and camber angle in automotive suspensions. The user presents a scenario with specific values: camber at -2.5 degrees, caster at +1.5 degrees, and SAI at 17 degrees. They calculate expected changes in camber when turning the wheel 30 degrees, predicting a resultant camber of +2.6 degrees. However, they express confusion over the visual discrepancy between their calculations and the actual appearance of the wheel's camber.
  • Understanding of automotive suspension geometry
  • Knowledge of caster angle, camber angle, and steering axis inclination (SAI)
  • Familiarity with the effects of wheel alignment on vehicle handling
  • Basic principles of trigonometry for angle calculations
  • Research the impact of dynamic suspension geometry on camber changes
  • Study the effects of wheel alignment on tire wear and handling
  • Learn about the role of suspension travel in camber angle adjustments
  • Explore advanced suspension tuning techniques for performance vehicles
Automotive engineers, suspension specialists, and car enthusiasts interested in understanding wheel alignment dynamics and improving vehicle handling characteristics.
krekquel
hello :)
hopefully i will be able to explain my question clearly.
i am trying to understand the effect that caster angles and steering axis inclination have on the camber angle of a wheel. imagine that we are looking at the left front wheel and turning it 90 degrees to the right (theoretically). the way i imagine it to work...
1. every degree of SAI (steering axis inclination) i have will translate to the same number of degrees of POSITIVE camber when the wheel is turned 90 degrees.
2. every degree of positive caster i have will translate to the same number of degrees of NEGATIVE camber when the wheel is turned 90 degrees.
correct so far?
if so...
let's assume the following about the front wheels of a vehicle:
camber = -2.5 degrees
castor = +1.5 degrees
SAI = 17 degrees
now... if i turn the wheels of the car are turned 30 degrees... i would expect the following to happen:
i would expect a +5.6 change in camber because of the steering axis (17 x 30/90)
i would expect a -0.5 change in camber because of the castor (1.5 x 30 / 90)
resulting in +2.6 degrees of camber when the wheel is turned 30 degrees.
but that can't be right. when i look at the wheel... it most definitely does not look 2.6 degrees tilted out.
so what am i missing here?
perhaps i am being impatient... anyone? :(
  • · Replies 20 ·
  • Sticky
  • · Replies 2K ·
60
878K
9K
9K
