Thread Closed
Finite Wings
Share Thread Thread Tools
Apr19-06, 03:20 AM   #1
Finite Wings
If I take an infinitely long, thin wing and measure its lift curve slope I should get 2pi.
Now if I take a 1/2-wing and fit 1 end to a plate and test it in a wind tunnel, it should simulate the flow around a full span wing, am I wrong? Therefore measuring lift and working out the CL values using the area of the half wing, air density, and flow speed I should get approximately the same results for CL as for a full wing (same section) twice the area and twice the aspect ratio (with no plates fitted to the ends).
I've done that experiment for a NACA 0015 aerofoil section and my results are confusing me. I understand the theory and the limitations of Prandtl's lifting line theory but this doesn't seem to be helping me here.
I was expecting the theoretical and experimental results to match up fairly well (looking at Prandtl's graphs they are pretty much identical).
The 1/2-wing I used was AR 3. Therefore it simulated the full wing AR 6. If I use AR 3 for the theoretical calculations the graphs match perfectly, but I can't do this, because the 1/2-wing AR 3 was simulating a wing AR 6 with that attachment plate on 1 end. So... experimentally the lift curve slope is 3.5rad-1 and theoretically it's 4.5rad-1.
Can anyone just point me in the direction of the reason for this massive difference? I'm guessing it's something to do with the 1/2-wing with a centre-line plate mount not properly simulating the flow around a full span wing, but this to me would suggest a steeper lift curve slope than theoretically predicted because there's 1 less wing tip vortex to cause more downwash over the rest of the wing.
I hope someone can make sense of that - I'm sure the only reason I can understand what I've written is because I know what I'm trying to say!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr19-06, 08:46 AM   #2
As is usually the case I answer my own question: the main (obvious reason) is that the theory I was using (Prandtl's lifting line theory) assumes invsicid flow and of course there are viscous effects (even if small).
Thread Closed
Thread Tools
Similar Threads for: Finite Wings
Thread Forum Replies
Wings with holes Mechanical Engineering 17
Aircraft Wings Mechanical Engineering 2
Fluid Dynamics (finite difference or finite volume) Advanced Physics Homework 1
Design of car wings Mechanical Engineering 11
lift of wings Aerospace Engineering 8
