Find Matrix A for 135° Clockwise Rotation in R^2
  • Thread starter Thread starter UrbanXrisis
    Direction
The discussion revolves around finding the matrix A that represents a linear transformation for a 135° clockwise rotation in R². Participants express uncertainty about the process, particularly in relation to transformations and trigonometric functions.
  • Participants discuss the relationship between linear transformations and rotations, with some suggesting that understanding the transformation's effect on standard basis vectors could be key. Questions arise about the application of trigonometric functions in this context, and there is a focus on visualizing the rotation.
The discussion is active, with participants exploring different interpretations of how to derive the transformation matrix. Some have provided guidance on using trigonometric functions to find the coordinates of rotated vectors, while others express confusion about the underlying concepts.
There is a noted lack of familiarity with the topic, as some participants mention that the homework question was unexpected and that they are unsure about the connection between linear transformations and rotations.
UrbanXrisis
Find the matrix A of the linear transformation T from [tex]R^2[/tex] to [tex]R^2[/tex] that rotates any vector through an angle of [tex]135^o[/tex] in the clockwise direction.
my book does not talk about how to answer this question. I've seen a change in 90 degrees, but I don't know how to do a 135 degree.
Look at the idea how to do it 90 degrees, the same idea applies.
I guessed on how to get the 90 degree one, since it was mulitple choice. so i don't actually know the process, could someone explain it to me?
You can look at what the transformation does to the standard basis, what is T(1,0) and T(0,1)? These determine the 1st and 2nd columns of A respectively and can be found using a little trig. More generally you can find a rotation by any angle this way.
how can this be found with trig? i don't even know how linear transformations have to do with rotations, not sure at all what is going on because this homework questions came out of the blue
I mean you can find T(1,0) and T(0,1) in terms of sin's and cos's of your angle. Can you find T(1,0) and T(0,1)? Drawing a picture will help.
A rotation about the origin is a linear transformation.
so T(1,0) represents sin(90) and T(0,1) = cos(90)?
No, T(1,0) is a vector. Did you draw a picture? Start with the vector (1,0). Rotate it 135 degrees clockwise. What quadrant is it in? What angle does it make with the x-axis? What are it's new coordinates?
it's in the thrid quadrant. it makes a 45 degree angle with the x axis. so the x is [tex]-\frac{\sqrt{2}}{2}[/tex] which would be the same for the y
Right, so that's the first column of the matrix for T. The second column is T(0,1), which you can find the same way.
  • · Replies 42 ·
