| Thread Closed |
solving for pH with diprotic/triprotic acids |
Share Thread | Thread Tools |
| Apr20-06, 11:13 AM | #1 |
i know if you have an acid, say .0001 M HCl, to get the pH you simply take the -log of the acid concentration (which is the same as [H+]), but what if you have a diprotic (H2SO4) or triprotic (H3PO4) acid...do you need to multiply the acid contentration by 2 or 3 to get the new H+ concentration BEFORE plugging it into -log[H+]?
and the same goes for pOH? eg. Mg(OH)2 needs to be multiplied by 2? |
| Apr20-06, 12:22 PM | #2 |
Check out these links. They should help in answering your question.
http://www.science.uwaterloo.ca/~cch.../polyprot.html http://www.sparknotes.com/chemistry/.../section1.html |
| Apr20-06, 01:03 PM | #3 |
Mg(OH)2 do not completely ionise in water as do for instance NaOH or KOH.
| Apr20-06, 06:22 PM | #4 |
Admin
Depending on your level of education - you may either calculate pH assuming full dissociation, or you may need to calculate dissociation equilibrium. Check out these links: general method for polyprotic acids and bases pH calculation and simplified method of pH calculation for polyprotic substances.
Best, Borek -- Chemical calculators at www.chembuddy.com equation balancer and stoichiometry calculator www.pH-meter.info |
| Thread Closed |
| Thread Tools | |
Similar Threads for: solving for pH with diprotic/triprotic acids
| calculating molecular mass of oxalic acid (diprotic acid) using only given #s? | Biology, Chemistry & Other Homework | 1 | ||
| triprotic acid? | Chemistry | 12 | ||
| pH with 2 acids | Biology, Chemistry & Other Homework | 5 | ||
| Acids and pH | Biology, Chemistry & Other Homework | 3 | ||
| for acids | Introductory Physics Homework | 1 | ||
