Power and Velocity: Can You Help Me Understand Better?
  • Context: Undergrad
  • Thread starter Thread starter kishtik
    Power
The discussion revolves around the relationship between power, force, and velocity in the context of vehicle acceleration. Participants explore the implications of the equation P=Fv, particularly in relation to how acceleration varies at different speeds, and the mechanics of engine performance.
  • One participant expresses confusion about the equation P=Fv, questioning how a car can have the same acceleration when increasing speed from 0 to 30 km/h compared to 30 to 60 km/h.
  • Another participant argues that the acceleration experienced at higher speeds can be influenced by engine characteristics, such as power delivery and torque curves, particularly in internal combustion engines.
  • A participant suggests that electric motors provide a clearer understanding due to their flatter torque curves, implying that this affects acceleration differently than traditional engines.
  • One comment highlights that if the energy required for acceleration were the same at different speeds, it would simplify complex tasks like space travel, indicating a misunderstanding of energy requirements at varying speeds.
  • Another participant points out that a rocket accelerates faster as its mass decreases, challenging the notion that energy requirements are consistent across different speed ranges.
  • Technical details are introduced regarding the relationship between torque, power, and angular frequency, suggesting a deeper exploration of engine performance characteristics.
Participants express differing views on the relationship between speed, acceleration, and energy requirements, indicating that the discussion remains unresolved with multiple competing perspectives presented.
There are references to specific engine performance characteristics and the implications of mass change in rockets, which may require further clarification and exploration of underlying assumptions.
kishtik
I cannot imagine P=F v cosa alhough I know its mathematical derivation.
Think a car speeding up from 0 to 30. It cannot have the same acceleration when it continues to 60 km/h. It seems nonsense.
Can you help me understand this better?
Any help is appreciated.
Why? It seems perfectly sensible to me. Maybe you are confused by the fact that with an internal combustion engine, power does not come on till you are at a sufficiently high engine speed. Try this: With a gear chosen so that you are near maximum power output for your car at so 50km/h, hit the throttle suddenly and note how hard it presses you back into your seat. That's a measure of acceleration. Now do the same at 100km/h. You will notice considerably less force pressing you into your seat at the higher speed.
Its much easier to think about it with an electric motor as it has a much flatter torque curve as krab implied.
Just a comment, but I think of it this way:
If 30 to 60 mph acceleration only required the same energy as 0 to 30 mph, than space travel would be far, far easier, and anyone could do it in their own backyard.
The torque delivered by the engine is a function of R.P.M. As the RPM increases there is a power peak range where there is a maximum power being delivered by the engine. As the rpm increases past that point the power starts to drop off.
There are some nice diagrams which illustrate this concept for model engines --
http://www.mh-aerotools.de/airfoils/engingeperformance.htm
As for the relationship P = Fv this applies in this case by noting what the force is. The torque on the wheels is being delivered the engine which exerting a torque by applying a force to the crankshaft through a lever arm. It can then be shown the relationship is
P = T*omega
where T = torque and omega = angular frequency.
Why the power/rpm curve has the shape that it does is a whole different and very interesting question. I've never looked into this myself. Perhaps someone has a good answer.
LOL. Still, that doesn't stop some of us from trying!
Not really. For low speed travel, a=f/m. A rocket actually accelerates FASTER the faster it gets because its mass is decreasing.
In which case one uses dp/dt = d(mv)/dt = m*dv/dt + v*dm/dt
Lots of thanks.
  • · Replies 95 ·
  • · Replies 21 ·
11K
  • · Replies 69 ·
18K
  • · Replies 20 ·
