How Does Car Suspension Behavior Change With a Malfunctioning Shock Absorber?
  • Thread starter Thread starter sparsh
    Cars Suspension
The discussion focuses on the impact of a malfunctioning shock absorber on car suspension behavior. A properly functioning shock absorber dampens vertical oscillations, resulting in a sinusoidal height variation above the road, while a malfunctioning one leads to increased amplitude and instability. When an 80 kg driver enters a 920 kg car, the vertical height decreases by 2 cm due to spring compression. The amplitude of vibration increases at a specific velocity, which can be calculated using the equation v=√2gh, where g is the acceleration due to gravity and h is the height of the hump.
  • Understanding of car suspension systems, including springs and shock absorbers
  • Knowledge of oscillation and damping principles in mechanical systems
  • Familiarity with basic physics equations, particularly v=√2gh
  • Concept of inertia and its effect on vehicle dynamics
  • Research the mechanics of shock absorbers and their role in vehicle stability
  • Study the effects of mass and inertia on car suspension performance
  • Learn about the principles of harmonic motion and damping in mechanical systems
  • Explore advanced calculations for vehicle dynamics over uneven surfaces
Automotive engineers, physics students, and anyone interested in understanding vehicle dynamics and suspension system performance.
sparsh
Hi
The question is
In practice the suspension system of cars consists of a spring under compression combined with a shock absorber.which damps the vertical oscillations of the car . Drwa sketch graphs one in each case to illustrate how the vertical height of the car above the road will vary with time as the car just passes over a hump if the shock absorber is a) functioning properly b) improper functioning...
when a driver of mass 80kg steps into a car of mass 920 kg the vertical height of the car decreases by 2cm . If the car is driven over a series of equally spaced humps the amplitude of vibration becomes much larger for a ertain velocity.
- Explain why this occurs and calculate the particular velocity .
Please help me out with the above problems. I could not get anything related to it .
The suspension system of a car consists of a spring and a shock absorber, which is designed to damp the vertical oscillations of the car when it passes over a hump. When the shock absorber is functioning properly, the vertical height of the car above the road will vary in a sinusoidal manner with time, as the car passes over the hump, with the amplitude of the oscillation gradually decreasing until it reaches a steady state. However, when the shock absorber is not functioning correctly, the amplitude of the oscillation will increase dramatically, resulting in a much higher vertical height of the car above the road.When a driver of mass 80kg steps into a car of mass 920 kg, the vertical height of the car decreases by 2cm. This is due to the additional weight of the driver, which causes the spring to compress slightly. When the car is travelling at a certain velocity over a series of equally spaced humps, the amplitude of vibration will increase due to the increased inertia of the car. This is because the car has more momentum at this velocity and therefore is able to overcome the damping forces of the shock absorber more easily. To calculate the particular velocity at which this occurs, we can use the equation v=√2gh, where g is the acceleration due to gravity and h is the height of the hump.
13K
22K
11K
11K
