Implicitly Deifned Parametrization
  • Thread starter Thread starter GregA
    Parametrization
The discussion revolves around finding the slope of a curve defined by two implicit equations at a specific parameter value. The equations involved are x + 2x^{\frac {3}{2}} = t^2 + t and y \sqrt{t+1} + 2t \sqrt{y} = 4, with a focus on differentiating these equations with respect to the parameter t.
  • Mixed
  • Participants discuss differentiating both equations with respect to t and finding dy/dx by dividing dy/dt by dx/dt. There is exploration of potential errors in calculations and assumptions regarding the values of x and y when t = 0. Some participants question the validity of certain solutions and the implications of taking positive versus negative roots in their calculations.
There is an ongoing exploration of different interpretations of the problem, particularly regarding the solutions for x when t = 0. Some participants have pointed out potential errors in reasoning, while others have acknowledged the existence of multiple solutions. Guidance has been offered regarding the nature of square roots and the implications of choosing positive or negative values.
Participants note that the problem involves implicit differentiation, and there is a discussion about the conventions used in determining roots of equations. The conversation reflects confusion over the definitions and implications of square roots in the context of real numbers.
GregA
Implicitly Defined Parametrization
I'm having difficulties with the following question, and having checked through my working several times I just can't find a problem...problem is, so far in the book implicit and parametric differentiation have been covered independently of each other and this question has just been thrown into the mix.
Find the slope when t = 0:
[tex]x + 2x^{\frac {3}{2}} = t^2 + t[/tex], [tex]y \sqrt{t+1} + 2t \sqrt{y} = 4[/tex]
I can't see any other way to work with this other than to differentiate both equations w.r.t.t, find dy/dx by dividing dy/dt by dx/dt, and then plug in my numbers at the end.
dx/dt: [tex]\frac{dx}{dt} +3 \sqrt{x} \frac{dx}{dt} = 2t + 1[/tex]
[tex]\frac{dx}{dt} =\frac{2t + 1}{3 \sqrt{x}+1}[/tex]
dy/dt: [tex]\sqrt{t+1} \frac{dy}{dt} + \frac {y}{2\sqrt{t+1}} + \frac{t}{\sqrt{y}}\frac{dy}{dt}+ 2\sqrt{y} = 0[/tex]
just going to assign dummy variables:[tex]a = \sqrt{y}, b = \sqrt{t+1}[/tex] whilst I rearrange things...
[tex]\frac{dy}{dt}(b + \frac{t}{a}) = -(\frac {y}{2b} +2a)[/tex]
[tex]\frac{dy}{dt}(\frac{ba +t}{a}) = -(\frac {y +4ab}{2b})[/tex]
[tex]\frac{dy}{dt} = -(\frac {a(y +4ab)}{2b(ba+t)}) = -(\frac {\sqrt{y}(y + 4\sqrt{y}\sqrt{t+1})}{2\sqrt{t+1}(\sqrt{y}\sqrt{t+1}+t)})[/tex]
dy/dx =[tex]-\frac {(3 \sqrt{x}+1)(\sqrt{y}(y + 4\sqrt{y}\sqrt{t+1}))} {(2t + 1)(2\sqrt{t+1}(\sqrt{y}\sqrt{t+1}+t))}[/tex]
By using t = 0 and finding x and y in the original equations I get x = 1/4 and y = 4
[tex]-\frac{(\frac{3}{2}+1)(8 + 16)}{4} = -15[/tex]
The answer I'm looking for however is -6. Is there some screw up with my working somewhere or am I using the wrong method?
I cannot graph any similar (but simpler) curves with Maxima to find the correct method neither because there doesn't seem to be a way to graph implicit expressions...nor will it differentiate one
EDIT: Indeed it gives -6 with x=0, y=4
dy/dx =[tex]-\frac {(3 \sqrt{x}+1)(\sqrt{y}(y + 4\sqrt{y}\sqrt{t+1}))} {(2t + 1)(2\sqrt{t+1})\sqrt{y}\sqrt{t+1}+t))}[/tex]
I did not check all the steps (the parenthesis don't match in the denominator in yoru final dy/dx) but how did you get x=1/4? When t =0, x=0 !
Fixed the parenthisis :smile:
By setting t =0 in:[tex]x + 2x^{\frac {3}{2}} = t^2 + t[/tex]
I get :[tex]x + 2x^{\frac {3}{2}} = 0[/tex]
[tex]x^{\frac {1}{2}} = -\frac{1}{2}[/tex]
x = 1/4
That response has just made me see how -6 is possible tho :smile:
x = 1/4
You are right in that there are two solutions. The other solution (x=0) gives indeed -6.
It`s all a question of which sign to take when calculating a square roo. For your answer to work one must use the convention that one must take the negative sign for a square root. I was assuming that the convention was to take the positive root.
Thankyou very much Nrged for putting my mind at ease and pointing out a solution I kept overlooking...what I did *lost* a solution! :smile:
Actually, no. [itex]x^{\frac{1}{2}}= -\frac{1}{2}[/itex] has no solution since the 1/2 power of any real number is non-negative. The only root os [itex]x+ 2x^{\frac{3}{2}}= 0 is 0.[/itex]
Thanks for pointing out where I am wrong HallsofIvy :smile: I won't make this same mistake twice.
[itex] So if we have x^2 = 4, the solution is only x=2 and cannot be x=-2? (where x is a real) ?[/itex]
no because x^2 = 4 does give two roots. +2 and -2.
-2*-2 = 4
2*2 = 4
-2*-2 = 4
2*2 = 4
I know, but HallsofIvy seems to imply the contrary which kind of surprised me . I'd like to understand what he meant (he is very knowledgeable so I must be missing his point entirely)
[itex] <br /> I am still confused by that statement: <b> since the 1/2 power of any real number is non-negative.</b>[/itex]
The equation x2= a has two solutions. They can be written [itex]\sqrt{a}[/itex] and [itex]-\sqrt{a}[/itex]. The reason why we need to write "+" and "-" is because [itex]\sqrt{a}[/itex] is defined to be the positive root! There is a difference between "the roots of the equation x2= a" and "the square root of a". The equation has two roots while the square root function, [itex]\sqrt{a}[/itex], is defined as the positive solution to x2= a.
a1/2 is also [ b]defined[/b] as [itex]\sqrt{a}[/itex], the positive real root of x2[/sub]= a.
Ok, that makes sense. Thank you.
  • · Replies 105 ·
13K
