Calculating Normalization Factor for 1s Atomic Orbital of H
  • Thread starter Thread starter geronimo123
    Normalization
The discussion revolves around calculating the normalization factor for the 1s atomic orbital of hydrogen, specifically focusing on the wavefunction \(\psi(r) = N \exp(-r / a_o)\). Participants are tasked with demonstrating that the normalization factor is \(1/(\Pi a_o^3)^{1/2}\) and are provided with relevant integration expressions.
  • Participants discuss the initial steps for normalizing the wavefunction, with emphasis on squaring the wavefunction and setting up the integral for normalization. There are questions about the integration process and how to apply given formulas effectively.
Some participants have provided guidance on how to approach the integration, suggesting specific techniques for handling the integrals involved. There is acknowledgment of the challenges faced with integration, and some participants express uncertainty about their progress, while others offer encouragement and hints.
Participants mention that the problem is set within the context of physical chemistry night classes, indicating a potential lack of recent experience with integration techniques. There is also a reference to specific integration limits and variables that may require clarification.
geronimo123
Hi all! I hope somebody is able to help me on my way with this question.
I have been asked to show that the Normalization factor for the 1s atomic orbital of H is [tex]1/(\Pi a_o^3)^\frac{1}{2}[/tex]. The wavefunction is [tex]\psi(r) = N exp(-r / a_o)[/tex]
I'm given [tex]dt = r^2 sin \Theta[/tex] and [tex]dr d\Theta d\Phi[/tex] and [tex]\int_{0}^{\infty}x^n e^{ax} dx=n!/a^n+1[/tex]
I must admit I'm clueless which direction to go. It was mentioned to me, that squaring the wavefunction is the first step, but I cannot arrive at the given constant. Am I starting off on the wrong foot?
Thanks for any input, in advance.
geronimo
I have been asked to show that the Normalization factor for the 1s atomic orbital of H is [tex]1/(\xi a_o^3)^\frac{1}{2}[/tex]. The wavefunction is [tex]\psi(r) = N exp(-r / a_o)[/tex]
I'm given [tex]d \Tau = r^2 sin \Theta[tex];[tex]dr d\Theta d\Phi[/tex] and [tex]\int_{0}^{\infty}x^n\e^-ax\dx=n!/a^n+1[/tex]<br /> <br /> I must admit I'm clueless which direction to go. It was mentioned to me, that squaring the wavefunction is the first step, but I cannot arrive at the given constant. Am I starting off on the wrong foot?<br /> <br /> Thanks for any input, in advance.<br /> <br /> geronimo[/tex][/tex]
[tex][tex] You have all the pieces in place.<br /> Just impose [itex]\int_0^\infty dr r^2 \int_0^{2 \pi} d\phi \int_0^\pi sin(\theta) d\theta \,\,N^2 e^{-2 r /a_0} =1[/itex] and solve for N.[/tex][/tex]
I must admit that my integration is not what it used to be. I'm taking some physical chemistry night classes where this problem was set. How might one initially solve for N?
The [tex]\phi[/tex] integral just adds a factor of [tex]2\pi[/tex], change variables in the [tex]\theta[/tex] integral to [tex]x=\cos(\theta)[/tex] and then it becomes a lot nicer.
Good luck.
Eoin Kerrane.
the theta integral gives 2. The phi integral gives 2 pi. For the r integral, you have a formula. just compare the r integral to the formual you have, term by term (what is n? etc) and you will have the result of the r integration. Then you have N^2 times an expression = 1 and you solve for N
Super guys, I have managed it finally thanks to your help. Best regards
  • · Replies 21 ·
