Epsilon and delta definition of limit
The discussion revolves around the epsilon-delta definition of limits in calculus, specifically focusing on demonstrating that the limit of the expression \(\frac{2x^3-y^3}{x^2+y^2}\) approaches 0 as \((x,y)\) approaches \((0,0)\). Participants explore different methods and implications of using the epsilon-delta definition in this context.
  • One participant suggests using polar coordinates to simplify the limit expression, leading to a formulation that isolates the distance from the origin in terms of \(r\).
  • Another participant proposes factoring out \(\sqrt[3]{2}x - y\) from the numerator, arguing that it approaches zero as \(x\) and \(y\) do, and asserts that the remaining factor is bounded.
  • A question is raised about the purpose of the epsilon-delta definition and what would occur in its absence.
  • In response, a participant explains that while limits can be defined without epsilon and delta, any alternative definition must still be equivalent to the epsilon-delta framework, emphasizing the foundational role of these concepts in the metric topology of the reals.
Participants express differing views on the necessity and implications of the epsilon-delta definition, with some focusing on its formal utility while others explore alternative definitions. There is no consensus on a singular approach to defining limits without epsilon and delta.
Some arguments rely on assumptions about boundedness and continuity that are not fully explored or resolved within the discussion. The effectiveness of alternative definitions of limits is also left ambiguous.
kidia
Can anyone help me on this question,Using [tex]\epsilon[/tex]-[tex]\delta[/tex] definition of a limit to show that
[tex]\lim[/tex] [tex]\frac {2x^3-y^3}{x^2+y^2}[/tex] = 0
(x,y)[tex]\rightarrow[/tex](0,0)
Like with most of these, I recommend changing to polar coordinates.
[itex]x= r cos(\theta)[/itex] and [itex]y= r sin(\theta)[/itex]
Then
[tex]\frac{2x^3-y^3}{x^2+y^2}= \frac{r^3(cos^3(\theta)- sin^3(\theta))}{r^2}= r(cos^3(\theta)- sin^3(\theta))[/tex]. Now the distance from (0,0) is entirely encapsulated in r.
or just factor out cubrt(2)x-y from the top, which certainly goes to zero as x and y do.
then it suffices to show the other factor remains bounded. but it obviously does, since the top has three terms, none as much as twice as large as the bottom, i.e. the other factor is bounded by 6.
anybody can explain what is the usage of epsilon delta definition of limit?what will happen without them?
What is your definition of a limit without using epsilons and deltas?
Their usage is to formally define limits. If you don't use them you have to give another way of defining limits. What is it? Whatever you come up with it must be equivalent to the epsilon and delta definition (or it will be convergence in some other sense: it is possible to define limits for any topology (which we won't define here), but in the reals we are using the metric topology, that is we are using balls of radii epsilon and delta to define the open sets. Thus whilst it is prefectly possible to not mention espilon or delta in a definition of limit, you are merely glossing over the fact that they are there. For instance, we may say a_n tends to a if every open set containing a contains all but finitely many of the a_n, for sequences, or we can say that f is continuous if for every open set in the range of f the inverse image is open. Both of these avoid mentioning epsilon and delta, but the open sets are defined in terms of open balls or intervals, which is just the epsilon delta thing in disguise. Suppose we wanted to verify that f(x)=x^2 from R to R is continuous, then pick some open interval in the image (a,b), and assume a>0, then the inverse image is (-sqrt(b),-sqrt(a)) union (sqrt(a),sqrt(b), if a<=0 and b>0 then the inverse image is (-sqrt(b),sqrt(b)), if b<0 then the inverse image is the empty set, thus x^2 is continuous. Easier, I think we all agree. Of course if f(x) is something that is not so easily 'inverted' then you're not necessarily going to be any better off than using epsilons and deltas, for instance, try doing f(x)=x^6-x^3+x^2+1)
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 18 ·
