Thermodynamics problem - filling a bottle from reservoir
  • Thread starter Thread starter Petrushka
    Thermodynamics
The problem involves a thermodynamics scenario where a bottle containing a perfect gas has its pressure doubled by adding gas from a high-pressure reservoir. The temperatures in both the bottle and reservoir are initially the same, and heat transfer is negligible. The task is to determine the fraction by which the mass of gas in the bottle increases using the first law of thermodynamics.
  • The original poster expresses uncertainty about their method and seeks hints or guidance. One participant questions the validity of the original poster's approach, suggesting that the pressure inside the bottle changes continuously and proposing an alternative method involving the first law for a control volume.
The discussion is ongoing, with participants exploring different interpretations of the problem. One participant has provided a method involving the first law of thermodynamics and conservation of mass, but notes a lack of information in the problem statement. There is no explicit consensus on the correct approach yet.
Participants mention the need for additional information, such as assumptions about temperature constancy, to proceed with the problem effectively. The original poster's confidence in their answer contrasts with their uncertainty about the method used.
Petrushka
I've been grappling with this problem for days, but can't produce the answer.
The problem can be summarised as follows:
We have a bottle containing a certain quantity of a perfect gas whose ratio of specific heat capacities is gamma. The pressure in the bottle is doubled by the admission of more gas from a high pressure reservoir in which the temperature and pressure remain constant. Initially the temperatures in the bottle and in the reservoir are the same, and heat transfer during the process is negligible.
Using only the 1st law, determine the fraction by which the mass of gas in the bottle increases.
I know the answer, and did come up with a method of producing the answer, but I was unconvinced by it.
Any help/hints/prodding in the right direction is appreciated.
The answer is 1/gamma.
Method:
Q=0.
-W = U2 - U1
W = pV (where V is the volume of the bottle)
U1 + pV = U2
H1 = U2
=> (initial mass) * Cp * T1 = (final mass) * Cv * T2
T1 = T2 (not sure about whether T1 does actually equal T2) thus (Final mass) / (Initial Mass) = Cp / Cv = 1/gamma
Petrushka, I don't think that's the right way to do it.
The pressure inside the bottle is continously changing, right? So the work done will not be PV.
In fact, here is how I would attempt it. First, you need to use the first law for a control volume. From that, you'll get
[tex]\frac{dE_{cv}}{dt} = \dot{Q} - \dot{W} + \dot{m_i}h_i[/tex]
(Note that here [itex]\dot{W}[/itex] is the boundary work (like expansion, etc) and is 0 in this problem)
And the conservation of mass gives
[tex]\frac{dm_{cv}}{dt} = \dot{m_i}[/tex]
substitute this in your first relation, and you'll get
[tex]\frac{d(m_{cv}\hat{U}_{cv})}{dt} = (h_i)\frac{dm_{cv}}{dt}[/tex]
Here, I'm stuck, and I think more info needs to be given in the question. For example, if the temperature is assumed to be constant, then from the ideal gas law, you can get
[tex]\dot{P}V=\dot{m_{cv}}RT[/tex]
[tex]\dot{m_i} = \frac{\dot{P}V}{RT}[/tex]
So if you substitute in terms of [itex]\dot{P}[/itex] and integrate, and substitute C_p to find H, you should be able to find the fraction by which the mass changes.
