Does light from a point source spread out?
The discussion revolves around the behavior of light from a point source, particularly in relation to its intensity at varying distances. Participants are exploring concepts related to the inverse square law and the characteristics of different types of light sources, including lasers and infrared sources.
  • Participants discuss the inverse square relationship of light intensity and question the teacher's assertion about light spreading. There is also inquiry into the definition of "strength of the light" and whether it refers to intensity.
The conversation is active, with participants providing insights into the nature of point sources and collimated beams. Some guidance has been offered regarding the characteristics of lasers and the importance of data sheets for specific devices. Multiple interpretations of light behavior are being explored.
There is mention of coursework requirements that involve measuring light intensity, and participants express concerns about the challenges of experimental setups and data acquisition.
Alvin
I have been looking into the strenth of an infrared light source at different distances from a point source. My teacher said that the light would not spread out but when I looked on the internet i found something that said the strength was inversly proportional to square of the distance from source, which is correct and why?
You are right. Maybe your teacher talking about a laser? It doesn't follow inverse square, but it does spread out.
When talking about a point source in optics it normally means that the physical size of the source of emission is very small. That means that all of the rays coming from the source originates at a "point" in space. It also means that the rays are diverging from the point source in "all" directions. I put the all in inverted commas since this is not possible in practice since the rays will normally fill only a small cone centered on the source and extending away from it. The amount of radiation from a point source will decrease according to the inverse square law with increasing distance.
Other sources of emission like lasers (and infrared lasers) also emit rays from a small region in space, but the rays coming from them are traveling parallel to each other, we say it is a collimated beam. In this case the amount of light will be constant irrespective at what distance you are from it (if you stay in line with the beam!).
Plasma lasers create their light in a tube. The rays bounce back and forth between the endpoints of the tube. The rays that are not traveling along the tube exit it along the side, while the rays traveling along the tube will eventually exit it at one of its ends thereby producing a collimated beam.
Solid state lasers emit their rays from a small region in space - the junction - the region where the semiconductor materials are joined. This will act like a point source, but normally a lens is used to collimate the rays by using a convex lens with a short focal length. The lens is positioned so that its focal point is located at the point source. This will cause the rays to be parallel on the other side of the lens. The lens need to be of such material so that it is transparent to the rays though!
http://www.repairfaq.org/sam/laserdio.htm"
Do you no if the strength of the light follows any pattern or formula?
What do you mean by "strength of the light" ? Are you referring to intensity ?
marlon.
ps : your teacher was talking about laser light indeed.
There are no conformed standards as far as the production of these devices are concerned. If you cannot get hold of the data sheet on the particular product it is best to investigate it experimentally, although finding a device that can actually measure the infrared light and setting up conditions for such a procedure might prove quite challenging! So I would opt for hunting for the data sheet if I were you. Look at the link that I inserted at the end of my post. It may answer some of your questions. Why are you interested in this property of your source?
Part of a courseworky thing
So they expect you to actually measure it? What do you know about the source? Producer? Product number?
  • · Replies 16 ·
  • · Replies 23 ·
