Thermodynamics: Small Question On Gibb's Free Energy
The discussion revolves around the Gibbs Free Energy in thermodynamics, specifically its dependence on the number of particles in a system. The original poster, Ben, seeks clarification on why the Gibbs Free Energy can be expressed as G(T, P, N) = Ng(T, P), where g(T, P) is independent of N.
  • Participants explore the implications of changing the number of particles while keeping temperature and pressure constant. Questions arise about the nature of intensive and extensive variables, particularly regarding pressure and its role in the context of Gibbs Free Energy.
The discussion is ongoing, with participants providing insights and asking questions to clarify concepts related to internal energy, entropy, and their relationships to the number of particles and volume. Some guidance has been offered regarding the linear dependence of Gibbs Free Energy on the number of particles.
There is some confusion regarding the definitions of intensive and extensive variables, as well as the assumptions made about the system's conditions. Participants are also grappling with the implications of doubling the system size on various thermodynamic properties.
doubleB
Hi to everyone at the forum.
I've attached the question in word format so you can see it properly but
it is basically this:
The Gibb's Free Energy is:
G(T, P, N) = U - TS + PV
Where N is the number of particles. (Only one type of particle is present).
Explain why the N-dependence of G is given by:
Where g(T, P) is independent of N.
So far the only thing I can think is that the number of particles, N, is not dependent on anything else and can be factored out. But to be honest I don't understand the question very well and can see how my answer (if it is an answer) is rather flimsy.
Thank you for any help you can give,
Ben
Hi Ben,
Welcome to Physics Forums! To understand what's going on here, ask yourself the following question: what would happen to the Gibbs free energy if I doubled the size of the system while keeping all the intensive variables (like T and P) fixed?
I thought that pressure was an extensive variable? In Gibb's free energy is it assumed that pressure is always constant?
I guess that if you doubled the size of the system, keeping pressure constant, then you would need twice as many particles. The Gibb's free energy would double as well?
Ben
Nope, pressure is an intensive variable. And yes, the Gibbs free energy describes a system where you control the pressure. You are right that the Gibbs potential doubles, but I sense some uncertainty on your part. To understand what's going on a little better, look at your expression for the Gibbs potential in terms energy, entropy, and volume. Doubling the size of the system will clearly double the volume (if you keep pressure and temperature fixed). What does such a doubling do to the entropy and energy?
Once you're satisfied that the Gibbs potential doubles when you double N and keep T and P fixed, it's easy to show that the Gibbs potential can depend on N only linearly.
God that was stupid of me! Of course pressure is extensive. I had (unwisely) consulted wikipedia where the entry is wrong for intensive/extensive.
Right well as far I can see I would say that by doubling the volume while keeping T and P fixed would result in a doubling of entropy and a halving of internal energy? Although now I'm feeling quite confused again; internal energy doesn't depend on anything but temperature, is that right?
In that case shouldn't it just remain constant if T is fixed?
Ben
I think you just typed the wrong word, but just to be sure, pressure is intensive.
You're right about entropy, but why do you think the energy would be cut in half? That doesn't make any sense. The internal energy of an ideal gas depends on T and N, but the dependence on N is simple. Think of it this way, if you had a monoatomic ideal gas at temperature T, the internal energy per particle is 3/2 kT. So if I have another system with twice as many particles at the same temperature, what would happen to the total internal energy?
Ok I see, so internal energy will double for twice the number of particles.
So overall will the - S and + V doubling sort of cancel out leaving the Gibb's energy doubled?
Also, why does the entropy double for double the size of the system? Is it because there are now twice as many particles in twice the volume and so they are more disordered?
Thanks for the continued help,
Ben
Oops, just noticed I typed extensive again in that post before! Yep, pressure's intensive.
  • · Replies 16 ·
9K
