Gyrator circuit that simulates an inductance
The discussion focuses on the design and simulation of a Gyrator circuit intended to simulate an inductance of 11.11mH using two operational amplifiers. The participant calculated the necessary resistance and capacitance values based on the input impedance formula, Zin=(R1*R3*R5)/(Zc*R4), and the inductance formula, L=(C*R1*R3*R5)/R4. The circuit's behavior was questioned, particularly regarding whether the inductance is floating or grounded, and the importance of connecting Vout to a load resistor for proper simulation in Electronics Workbench.
  • Understanding of Gyrator circuits and their applications
  • Familiarity with operational amplifiers (op-amps)
  • Knowledge of SPICE simulation tools, specifically Electronics Workbench
  • Basic concepts of impedance and inductance calculations
  • Research the principles of Gyrator circuits and their configurations
  • Learn how to properly set up SPICE simulations for inductive behavior
  • Explore the relationship between resistance, capacitance, and inductance in Gyrator circuits
  • Investigate common issues in simulating floating vs. grounded inductors
Electronics students, circuit designers, and engineers interested in simulating inductive components using Gyrator circuits.
infirmus
Hi,
I'm working on an assigment where I'm given an circuit which contains two op-amps and I am told it is a Gyrator circuit that simulates an inductance.
I am required to calculate the values of the resistances and the capacitor in the circuit so that the gyrator has an inductance of 11.11mH and then simulate the circuit (in Electronics Workbench) and show a demonstrator the results..
Only problem is when I simulate the circuit I can't get it to act like an inductor.
I'm not sure if the inductance is between the Vin and Vout (floating?) or between Vin and ground.
The circuit diagram I have posted below shows values for the capacitor and resistors that I calculated from finding an expression for Zin (input impedence). Zin=(R1*R3*R5)/(Zc*R4)
The expression for the inductance that I found was L=(C*R1*R3*R5)/R4
The resistances had to be between 0.1k ohm and 10k ohm and the capacitance between 10pF and 500pF. I just arbitarily chose the values of the resistors and capacitance so the inductance was 11.11mH. Is this OK or is there some other condition which should have been met?
Pretty funny -- I googled gyrator tutorial, and got lots of hits...for washing machines! LOL.
But here's a link into wikipedia for a simple gyrator circuit in case you haven't already seen it:
http://en.wikipedia.org/wiki/Gyrator
There are also other links on that page to more complicated gyrator circuits. The typical gyrator inductor circuit is not floating like yours is -- it looks like an inductor with one side grounded. But a floating inductor gyrator circuit makes sense for a general element. To answer your question, yes, it looks like that circuit is meant to simulate an inductor's two end points between Vin and Vout. In your SPICE simulation, how are you trying to see if this circuit behaves like an inductor? Are you connecting Vout to a load resistor and driving a square wave voltage source into Vin, for example?
9K
  • · Replies 36 ·
