Confusion regarding sin and cos
The discussion revolves around the application of sine and cosine functions in physics problems, specifically in the context of calculating torque related to tension in a wire. Participants are exploring the reasoning behind using sine in the torque equation and questioning the underlying principles of trigonometric functions in relation to physical scenarios.
  • Participants discuss the relationship between angles and the sine/cosine functions, particularly in the context of torque and tension. There are attempts to correlate the use of sine with vertical motion and cosine with horizontal motion. Some participants question the validity of these associations and suggest a deeper understanding of torque and its calculation through trigonometric definitions.
The discussion is active, with participants providing insights into the definitions of torque and the role of trigonometric functions. There is a mix of interpretations regarding the application of sine and cosine, and some guidance has been offered on visualizing the problem and understanding the geometric relationships involved.
Participants note the importance of correctly setting up axes and understanding the definitions of sine and cosine in the context of the problem. There is an emphasis on avoiding simplistic associations that may lead to errors in reasoning.
ness9660
Generally I am confused about the use of sin and cos in physics problems.
http://img188.imageshack.us/img188/3162/eg2gu.gif
The torque about the beam's attachment to the wall is:
T * 8 * sin(53)
Where T is the tension of the wire.
Why is sin the choice and not cos?
The best correlation I've come up with so far was in two dimensional collisions, where motion in the y-axis is always associated with sin, while the x-axis with cos.
Can anyone give any insight?
[snip]
better:
cos goes with ADJACENT side
sin goes with OPPOSITE side
(from the definitions of sin() and cos(), of course).
No, don't use "blind" methods of association to learn stuff like that - you will make mistakes later on (and they are not always applicable). (edit : this is in reference to the orig. post, not robphy's reply)
The magnitude of the moment (torque) of a force about a point is the product of the force and the perpendicular distance from the point to the line of force (this is called the "moment arm"). Draw a perpendicular from the point of attachment at the wall to the wire (which corresponds to the direction of the tensional force) and calculate the length of the perpendicular segment with trig.
More properly, the definition of torque is [tex]\tau[/tex] = r X F, meaning the cross product of the position vector of the point of application of force (taking the fulcrum to be the origin) and the force itself.
By the definition of the cross product, the magnitude of the torque will always come out to the product of the magnitudes of the distance and the force times the sine of the angle between them, i.e.
[tex]|\tau| = |r||F|\sin \theta[/tex]
which you can verify is the case in this problem too (though in this case, [tex]\theta[/tex] is actually (180 - 53) = 127 degrees, which has the same sine as 53 degrees). The only thing is that torque (properly defined) is a vector quantity, and its direction is at right angles to the other two vectors, in this case, the torque vector will be pointing out of the page at you.
Good info already stated. What i'll say is that perhaps it's better to view the result as 8*(T*sin(53)). Now look at the term in parenthesis...
T*sin(53). what would happen to the tension in the rope if the 53 degrees went to 0? Since the rope and the beam would then be the same length the tension would be 0 also. So ask the question "if theta went to 0, what trig function sin or cos would also give me 0?" You have to have the problem set up right with axes and all that, but this helps when trying to decide between sin and cos...
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 42 ·
