Skipping numbers in lists in Mathematica
  • Context: Mathematica
  • Thread starter Thread starter laminatedevildoll
    Mathematica Numbers
The discussion focuses on manipulating data in Mathematica by skipping numbers in a list. The user successfully generates a histogram from a dataset containing 22,000 integers but seeks to extract every 256th number for further analysis. They initially attempted to use the `takedata` option and a `For` loop but found success with a `Do` loop. The provided code effectively appends every 256th number to a new list, but the user struggles to iterate this process for different initial observations (initobs) to create multiple lists.
  • Familiarity with Mathematica programming language
  • Understanding of list manipulation techniques in Mathematica
  • Knowledge of control structures such as loops in Mathematica
  • Basic data analysis concepts, particularly histogram generation
  • Learn about advanced list manipulation functions in Mathematica
  • Explore the use of `Table` for generating multiple lists efficiently
  • Investigate the `BinaryReadList` function for reading large datasets
  • Study the `Append` function and its performance implications in Mathematica
Data analysts, researchers, and Mathematica users who need to manipulate large datasets and generate histograms from selective data points.
laminatedevildoll
Hi,
I am new to mathematica, and part of the program I have to write includes reading a file and manipulating the data for research. This file has around 22,000 numbers listed in it. I've already figured out how to look at those numbers and generate a histogram. However, what if I want to skip over numbers, meaning that now I want to read every 256th number until the end of my data set and save it each time under the same name, i.e data1, so I can generate a new histogram with these numbers. I've already tried the takedata option, without much luck.
I'd appreciate any help.
One simple way to do it would be to write a For [ ] - loop over your data with the appropriate incrementation and writing the operation (the save) in the body of the for-statement.
Okay, I figured out how to skip numbers by using a Do loop.
Here's my code so far...
data = BinaryReadList[file,"Integer16"]
lngth = Length[data]
stepsize = 255
numiter = IntegerPart[lngth/stepsize]
initobs=1
data1={}
Do[data1=Append[data1,data[[i]]], {i,initobs,numiter*stepsize,stepsize}]
Readlist[data1]
However, I need to evaluate this 256 times where initobs = 1,2...256. I tried to put this whole expression in a do loop, so that it could output 256 different list for different values of initobs, but it doesn't work. What am I doing wrong?
  • · Replies 22 ·
10K
